0011607VTK(No Category)public2010-12-15 05:052015-01-09 13:43
ReporterPaul Melis
Assigned ToUtkarsh Ayachit
PrioritynormalSeveritycrashReproducibilityalways
StatusclosedResolutionfixed
PlatformGNU/LinuxOSUbuntuOS Version8.04
Product Version
Target VersionFixed in Version6.2.0
Summary0011607: Segfault with vtkXMLPImageDataReader
DescriptionI converted a set of image slices in PNG format to a .pvti file + set of .vti files, using a vtkPNGReader connected to a vtkXMLPImageDataWriter. I'm not sure it's relevant for this bug to occur, but I used SetDataModeToAppended() and EncodeAppendedDataOff() on the writer. The slices were 2000x2000 pixels each, single channel 8-bit. In total 834 slices.
Reading in this dataset in Paraview 3.8.1 I got a crash and managed to reduce it to an issue in VTK 5.6.1 (VTK 5.4.2 seems to be immune).
Steps To ReproduceI attached a simplified dataset, which leaves out most of the piece files, but should be enough to reproduce the crash.
paulm@sara0143:/scratch/paulm/coraltest/bug$ cat read.py
#!/usr/bin/env python
import sys, vtk
dr = vtk.vtkXMLPImageDataReader()
dr.SetFileName(sys.argv[1])
dr.Update()
paulm@sara0143:/scratch/paulm/coraltest/bug$ ls -l dummy*
-rw-r--r-- 1 paulm Domain Users 212348 2010-12-14 16:36 dummy_387.vti
-rw-r--r-- 1 paulm Domain Users 58666 2010-12-14 16:35 dummy.pvti
paulm@sara0143:/scratch/paulm/coraltest/bug$ ./read.py dummy.pvti
Segmentation fault (core dumped)
#0 0xb75cfa55 in memcpy () from /lib/tls/i686/cmov/libc.so.6
#1 0xb621ed98 in vtkXMLPStructuredDataReader::CopySubExtent (this=0x81c48d8, inExtent=0x81c4a28, inDimensions=0x81c4a40, inIncrements=0x81c4a4c, outExtent=0x81c49b0, outDimensions=0x81c49c8, outIncrements=0x81c49d4, subExtent=0x81c49f8, subDimensions=0x81c4a10,
    inArray=0x86c1d98, outArray=0x8388e50) at /scratch/paulm/vtk-5.6.1/IO/vtkXMLPStructuredDataReader.cxx:413
#2 0xb621ef4e in vtkXMLPStructuredDataReader::CopyArrayForPoints (this=0x81c48d8, inArray=0x86c1d98, outArray=0x8388e50) at /scratch/paulm/vtk-5.6.1/IO/vtkXMLPStructuredDataReader.cxx:331
#3 0xb6216b1b in vtkXMLPDataReader::ReadPieceData (this=0x81c48d8) at /scratch/paulm/vtk-5.6.1/IO/vtkXMLPDataReader.cxx:400
#4 0xb621f094 in vtkXMLPStructuredDataReader::ReadPieceData (this=0x81c48d8) at /scratch/paulm/vtk-5.6.1/IO/vtkXMLPStructuredDataReader.cxx:315
#5 0xb6215d09 in vtkXMLPDataReader::ReadPieceData (this=0x81c48d8, index=387) at /scratch/paulm/vtk-5.6.1/IO/vtkXMLPDataReader.cxx:376
#6 0xb621ff9e in vtkXMLPStructuredDataReader::ReadXMLData (this=0x81c48d8) at /scratch/paulm/vtk-5.6.1/IO/vtkXMLPStructuredDataReader.cxx:156
#7 0xb622f39c in vtkXMLReader::RequestData (this=0x81c48d8, outputVector=0x837f3f0) at /scratch/paulm/vtk-5.6.1/IO/vtkXMLReader.cxx:524
#8 0xb622dc02 in vtkXMLReader::ProcessRequest (this=0x81c48d8, request=0x83893a8, inputVector=0x0, outputVector=0x837f3f0) at /scratch/paulm/vtk-5.6.1/IO/vtkXMLReader.cxx:1201
0000009 0xb67a2ed0 in vtkExecutive::CallAlgorithm (this=0x837f398, request=0x83893a8, direction=1, inInfo=0x0, outInfo=0x837f3f0) at /scratch/paulm/vtk-5.6.1/Filtering/vtkExecutive.cxx:747
#10 0xb678bf22 in vtkDemandDrivenPipeline::ExecuteData (this=0x837f398, request=0x83893a8, inInfo=0x0, outInfo=0x837f3f0) at /scratch/paulm/vtk-5.6.1/Filtering/vtkDemandDrivenPipeline.cxx:507
0000011 0xb67905df in vtkDemandDrivenPipeline::ProcessRequest (this=0x837f398, request=0x83893a8, inInfoVec=0x0, outInfoVec=0x837f3f0) at /scratch/paulm/vtk-5.6.1/Filtering/vtkDemandDrivenPipeline.cxx:279
#12 0xb6912220 in vtkStreamingDemandDrivenPipeline::ProcessRequest (this=0x837f398, request=0x83893a8, inInfoVec=0x0, outInfoVec=0x837f3f0) at /scratch/paulm/vtk-5.6.1/Filtering/vtkStreamingDemandDrivenPipeline.cxx:202
#13 0xb67900d6 in vtkDemandDrivenPipeline::UpdateData (this=0x837f398, outputPort=0) at /scratch/paulm/vtk-5.6.1/Filtering/vtkDemandDrivenPipeline.cxx:449
#14 0xb6910c59 in vtkStreamingDemandDrivenPipeline::Update (this=0x837f398, port=0) at /scratch/paulm/vtk-5.6.1/Filtering/vtkStreamingDemandDrivenPipeline.cxx:246
#15 0xb67a39e3 in vtkExecutive::Update (this=0x837f398) at /scratch/paulm/vtk-5.6.1/Filtering/vtkExecutive.cxx:315
#16 0xb678e4a5 in vtkDemandDrivenPipeline::Update (this=0x837f398) at /scratch/paulm/vtk-5.6.1/Filtering/vtkDemandDrivenPipeline.cxx:312
#17 0xb69081c5 in vtkStreamingDemandDrivenPipeline::Update (this=0x837f398) at /scratch/paulm/vtk-5.6.1/Filtering/vtkStreamingDemandDrivenPipeline.cxx:226
#18 0xb6710fd5 in vtkAlgorithm::Update (this=0x81c48d8) at /scratch/paulm/vtk-5.6.1/Filtering/vtkAlgorithm.cxx:1167
#19 0xb6ac3b78 in PyvtkAlgorithm_Update (self=0xb751b800, args=0xb751b02c) at /scratch/paulm/vtk-5.6.1-debug/Filtering/vtkAlgorithmPython.cxx:1372
#20 0x080c9ab3 in PyEval_EvalFrameEx (f=0x819050c, throwflag=0) at ../Python/ceval.c:3573
#21 0x080cb1f7 in PyEval_EvalCodeEx (co=0xb74e59f8, globals=0xb7534acc, locals=0xb7534acc, args=0x0, argcount=0, kws=0x0, kwcount=0, defs=0x0, defcount=0, closure=0x0) at ../Python/ceval.c:2836
#22 0x080cb347 in PyEval_EvalCode (co=0xb74e59f8, globals=0xb7534acc, locals=0xb7534acc) at ../Python/ceval.c:494
#23 0x080ea818 in PyRun_FileExFlags (fp=0x816b008, filename=0xbfda1368 "./read.py", start=257, globals=0xb7534acc, locals=0xb7534acc, closeit=1, flags=0xbfd9f778) at ../Python/pythonrun.c:1273
#24 0x080eaab9 in PyRun_SimpleFileExFlags (fp=0x816b008, filename=0xbfda1368 "./read.py", closeit=1, flags=0xbfd9f778) at ../Python/pythonrun.c:879
#25 0x08059335 in Py_Main (argc=2, argv=0xbfd9f844) at ../Modules/main.c:523
#26 0x080587f2 in main (argc=Cannot access memory at address 0x44) at ../Modules/python.c:23
Additional InformationRelevant valgrind error:
==13663== Invalid write of size 1
==13663== at 0x4024DB6: memcpy (mc_replace_strmem.c:482)
==13663== by 0x5B3DD97: vtkXMLPStructuredDataReader::CopySubExtent(int*, int*, int*, int*, int*, int*, int*, int*, vtkDataArray*, vtkDataArray*) (vtkXMLPStructuredDataReader.cxx:413)
==13663== by 0x5B3DF4D: vtkXMLPStructuredDataReader::CopyArrayForPoints(vtkDataArray*, vtkDataArray*) (vtkXMLPStructuredDataReader.cxx:331)
==13663== by 0x5B35B1A: vtkXMLPDataReader::ReadPieceData() (vtkXMLPDataReader.cxx:400)
==13663== by 0x5B3E093: vtkXMLPStructuredDataReader::ReadPieceData() (vtkXMLPStructuredDataReader.cxx:315)
==13663== by 0x5B34D08: vtkXMLPDataReader::ReadPieceData(int) (vtkXMLPDataReader.cxx:376)
==13663== by 0x5B3EF9D: vtkXMLPStructuredDataReader::ReadXMLData() (vtkXMLPStructuredDataReader.cxx:156)
==13663== by 0x5B4E39B: vtkXMLReader::RequestData(vtkInformation*, vtkInformationVector**, vtkInformationVector*) (vtkXMLReader.cxx:524)
==13663== by 0x5B4CC01: vtkXMLReader::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) (vtkXMLReader.cxx:1201)
==13663== by 0x5251ECF: vtkExecutive::CallAlgorithm(vtkInformation*, int, vtkInformationVector**, vtkInformationVector*) (vtkExecutive.cxx:747)
==13663== by 0x523AF21: vtkDemandDrivenPipeline::ExecuteData(vtkInformation*, vtkInformationVector**, vtkInformationVector*) (vtkDemandDrivenPipeline.cxx:507)
==13663== by 0x523F5DE: vtkDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) (vtkDemandDrivenPipeline.cxx:279)
==13663== Address 0x2996c1c7 is not stack'd, malloc'd or (recently) free'd
TagsNo tags attached.
Project
Type
Attached Filestgz file icon files.tgz [^] (219,190 bytes) 2010-12-15 05:05
related to 0012753closedUtkarsh Ayachit Segfault when reading .vti file written by VTK itself
related to 0012647closedUtkarsh Ayachit Segfault when reading parallel image data
-  Notes
(0033521)
2014-10-02 15:10
Topic for review:
http://review.source.kitware.com/#/t/4768 [^]
(0033534)
2014-10-02 15:51
merged in git/master
- Issue History
2010-12-15 05:05 Paul Melis New Issue
2010-12-15 05:05 Paul Melis File Added: files.tgz
2014-10-02 15:06 Utkarsh Ayachit Relationship added related to 0012753
2014-10-02 15:07 Utkarsh Ayachit Relationship added related to 0012647
2014-10-02 15:09 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2014-10-02 15:09 Utkarsh Ayachit Status expired => backlog
2014-10-02 15:09 Utkarsh Ayachit Resolution open => reopened
2014-10-02 15:10 Utkarsh Ayachit Note Added: 0033521
2014-10-02 15:10 Utkarsh Ayachit Status backlog => gerrit review
2014-10-02 15:51 Utkarsh Ayachit Note Added: 0033534
2014-10-02 15:51 Utkarsh Ayachit Status gerrit review => closed
2014-10-02 15:51 Utkarsh Ayachit Resolution reopened => fixed
2014-10-02 15:51 Utkarsh Ayachit Fixed in Version => 6.2.0
2015-01-09 13:42 Utkarsh Ayachit Source_changeset_attached => VTK master 82085ea8
2015-01-09 13:43 Utkarsh Ayachit Source_changeset_attached => VTK master 51996a64
Powered by Mantis Bugtracker
