0011601 | ParaView | Feature | public | 2010-12-13 15:16 | 2011-01-20 22:05 | ||||
Target Version | 3.10.1 | Fixed in Version | 3.10 | ||||||
Summary | 0011601: Normal Glyphs Filter has incorrect behavior | ||||||||
Description | The normal Glyph filter has incorrect behavior. To quote Ken: The issue is in how the Normal Glyphs filter computes the normals. Internally, the Normal Glyphs filter uses the Generate Surface Normals filter to create normals. That filter has an option called Consistency that attempts to flip normals to make them point the same way on a connected surface. Probably the Normal Glyphs filter should turn that off (or at least expose it). That should be an easy change to make if you submit a bug. So, I propose that the Normal Glyph filter leaves the normals the way they should naturally be (without flipping them), but expose the option to make these normals "Consistent". | ||||||||
(0024926) Utkarsh Ayachit (administrator) 2011-01-19 11:59 |
commit 9d113d46fd24b6f216704420de9d10358f996945 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Jan 19 11:57:22 2011 -0500 Fixed BUG 0011601. Expose "Consistency" property as requested. |
(0024980) Alan Scott (manager) 2011-01-20 22:05 |
Excellent. Tested local server, Windows, trunk. |
2010-12-13 15:16 | Alan Scott | New Issue | |
2011-01-19 11:59 | Utkarsh Ayachit | Note Added: 0024926 | |
2011-01-19 11:59 | Utkarsh Ayachit | Status | backlog => @80@ |
2011-01-19 11:59 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
2011-01-19 11:59 | Utkarsh Ayachit | Resolution | open => fixed |
2011-01-19 11:59 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2011-01-20 22:05 | Alan Scott | Note Added: 0024980 | |
2011-01-20 22:05 | Alan Scott | Status | @80@ => closed |
