0011587ParaViewBugpublic2010-12-08 18:502011-01-04 22:09
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PriorityhighSeveritymajorReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version3.10
Summary0011587: Select points on doesn't work for Linux, remote server
DescriptionParaView remote server (16 processes, but I bet it replicates with 2-4), Linux client, trunk.
Open disk_out_ref.exo.
Surface with edges.
Select points. Rubber band select over a large area of the base of the disk, or one point - it doesn't matter. Nothing gets selected.
This must be fixed for the 3.10.0 release.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0023853)
Robert Maynard (developer)
2010-12-09 15:06
What version of mpi is being used on the server? I am currently only able to replicate a problem with selection and OpenMPI 1.5
(0023854)
Alan Scott (manager)
2010-12-09 15:20
This is the lastest version of openmpi that I have available to me on this machine: /.../openmpi/intel-11.1-f064-c064/openmpi-1.4.2_oobpr/...
(0023856)
2010-12-09 15:20
Oh, one more note. Windows client seemed to work, Linux client shows the bug.
(0023924)
2010-12-13 10:23
Could I get the following information:
GCC Version and does cell surface selection work?
(0023929)
2010-12-13 13:56
Fixed the issue that point selection in client server mode was not returning and results. This also fixes an issue when selection was the first interactive render action.
Commit SHA1: 51611952 on ParaView master.
(0023931)
2010-12-13 15:29
Reopening since I am concerned that the patch didn't fix client server reverse connection.
Alan would you be able to confirm that you are using reverse connection when you see this problem?
(0023932)
2010-12-13 15:32
Unless there is a strange setup, we always use reverse connection. Yes, this is also using reverse connection.
(0023946)
2010-12-13 18:31
I just checked, and it does work local server.
(0024338)
2010-12-29 11:48
commit 4ad5f7926e7b64ee0812eeb808a7f1783d071a34
Merge: b0a3ea0 c6e6f1d
Date: Wed Dec 29 11:42:34 2010 -0500
    Merge topic 'bug_11587_point_selection'
    c6e6f1d Forwarding VTK to bring in fixes to hardware selector.
    b533076 Fixed BUG 0011587. Point selections weren't working in parallel.
(0024408)
2011-01-04 22:08
Tested Linux client, remote server, trunk.
 Issue History
2010-12-08 18:50 Alan Scott New Issue
2010-12-09 09:52 Robert Maynard Assigned To => Robert Maynard
2010-12-09 09:52 Robert Maynard Status backlog => tabled
2010-12-09 15:06 Robert Maynard Note Added: 0023853
2010-12-09 15:20 Alan Scott Note Added: 0023854
2010-12-09 15:20 Robert Maynard Note Added: 0023855
2010-12-09 15:20 Robert Maynard Status tabled => @20@
2010-12-09 15:20 Alan Scott Note Added: 0023856
2010-12-09 15:20 Alan Scott Status @20@ => tabled
2010-12-09 15:21 Robert Maynard Note Deleted: 0023855
2010-12-13 10:23 Robert Maynard Note Added: 0023924
2010-12-13 10:23 Robert Maynard Status tabled => @20@
2010-12-13 13:56 Robert Maynard Note Added: 0023929
2010-12-13 13:56 Robert Maynard Status @20@ => @80@
2010-12-13 13:56 Robert Maynard Fixed in Version => 3.10.shortlist
2010-12-13 13:56 Robert Maynard Resolution open => fixed
2010-12-13 15:29 Robert Maynard Note Added: 0023931
2010-12-13 15:29 Robert Maynard Status @80@ => @20@
2010-12-13 15:29 Robert Maynard Resolution fixed => reopened
2010-12-13 15:32 Alan Scott Note Added: 0023932
2010-12-13 15:32 Alan Scott Status @20@ => tabled
2010-12-13 18:31 Alan Scott Note Added: 0023946
2010-12-29 09:35 Robert Maynard Assigned To Robert Maynard => Utkarsh Ayachit
2010-12-29 11:48 Utkarsh Ayachit Note Added: 0024338
2010-12-29 14:36 Utkarsh Ayachit Status tabled => @80@
2010-12-29 14:36 Utkarsh Ayachit Fixed in Version 3.10.shortlist => 3.10
2010-12-29 14:36 Utkarsh Ayachit Resolution reopened => fixed
2011-01-04 22:08 Alan Scott Note Added: 0024408
2011-01-04 22:08 Alan Scott Status @80@ => closed
