0011581 | ParaView | Bug | public | 2010-12-08 10:43 | 2011-01-06 17:30 | ||||
Reporter | Stephane P | ||||||||
Platform | Linux | OS | ubuntu 64bit | OS Version | 10.10 | ||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0011581: Point sprite plugin "Scale By" functionnality buggy | ||||||||
Description | The "Scale By" functionnality seems to be not functionnal : selecting an array to scale by does not change the radius of the points sprite, neither in sphere mode nor in Texture mode. Furtermore, for fields with number of components > 1, the components are not visible. | ||||||||
Steps To Reproduce | Load point sprite plugin create wavelet source set representation to Point Sprite Set rendering mode to "Sphere" Set Scale By parameter to RTData --> the point sprite size is not varying as it should. | ||||||||
Project | ParaViS | ||||||||
(0024345) Utkarsh Ayachit (administrator) 2010-12-31 09:21 |
commit 2e26f5195e6be01427d586c15b242df04f34fb4e Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Dec 31 09:17:09 2010 -0500 Fixed BUG 0011581. Fixed issues with scale-by parameter for point-sprite. Fixed issues with scale by. Also fix the issue with updating the gui for component numbers. |
(0024501) Alan Scott (manager) 2011-01-06 17:30 |
Nice feature! I tried testing this fix ssh -X'ing into a different Linux box, and it fails. This is because the ssh doesn't support Shaders, which are required. tested local server, Windows client, trunk. |
2010-12-08 10:43 | Stephane P | New Issue | |
2010-12-31 09:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-12-31 09:16 | Utkarsh Ayachit | Status | backlog => tabled |
2010-12-31 09:21 | Utkarsh Ayachit | Note Added: 0024345 | |
2010-12-31 09:21 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-12-31 09:21 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
2010-12-31 09:21 | Utkarsh Ayachit | Resolution | open => fixed |
2011-01-06 17:30 | Alan Scott | Note Added: 0024501 | |
2011-01-06 17:30 | Alan Scott | Status | @80@ => closed |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
