0011549ParaViewBugpublic2010-12-01 11:222016-08-12 09:58
ReporterKen Moreland
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformLinuxOSOpenSuseOS Version11.3
Product Version
Summary0011549: Automatic values not set in object inspector when using forign language
DescriptionA user with OpenSuse 11.3 using a system language of German noticed some odd behavior while performing the Vector Visualization exercises in The ParaView Tutorial (exercises 2.9 and 2.10). When adding a filter that has an object inspector item that is automatically set, they were not set properly. For example, when creating a stream tracer filter, the radius of the seeds is set to 0 rather than to some value based on the size of the geometry. Likewise, when creating a glyph filter the scale factor is set to 0 rather than an automatic value based on the size of the geometry and the size of the vectors.
I suspect that Qt is translating the name of the widgets, and then a latter comparison to a non-translated name is failing.
TagsNo tags attached.
Project
Topic Name
Type
related to 0011614closedKitware Robot Odd behavior with calculator and european number formatting
-  Notes
(0037899)
Kitware Robot (administrator)
2016-08-12 09:58
Resolving issue as `moved`.
- Issue History
2010-12-01 11:22 Ken Moreland New Issue
2010-12-16 10:27 Ken Moreland Relationship added related to 0011614
2016-08-12 09:58 Kitware Robot Note Added: 0037899
2016-08-12 09:58 Kitware Robot Status expired => closed
2016-08-12 09:58 Kitware Robot Resolution open => moved
2016-08-12 09:58 Kitware Robot Assigned To => Kitware Robot
Powered by Mantis Bugtracker
