0011354ParaViewBugpublic2010-10-22 19:442010-10-27 20:45
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PriorityhighSeveritymajorReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.10Fixed in Version3.10
Summary0011354: Display/ Transform section is confusing
DescriptionI just had a user try to use the Display/ Transform section of ParaView, and see the results with a selection. It didn't work.
I would recommend that we either delete this section of the Display tab, and finish implementing all datatypes for the transform filter, or add a comment and warning above the Transform, right on the Display tab, explaining what we are doing and why it won't work with some functionality.
TagsNo tags attached.
Project
Topic Name
Type
-  Notes
(0022666)
2010-10-23 07:25
What version did you try? It should work with 3.9
(0022718)
Alan Scott (manager)
2010-10-27 20:45
Boy, that was a quick fix! Tested local server, trunk, Windows.
- Issue History
2010-10-22 19:44 Alan Scott New Issue
2010-10-22 19:45 Alan Scott Target Version => 3.10
2010-10-23 07:25 Utkarsh Ayachit Note Added: 0022666
2010-10-23 07:25 Utkarsh Ayachit Status backlog => @80@
2010-10-23 07:25 Utkarsh Ayachit Fixed in Version => 3.10
2010-10-23 07:25 Utkarsh Ayachit Resolution open => fixed
2010-10-23 07:25 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2010-10-27 20:45 Alan Scott Note Added: 0022718
2010-10-27 20:45 Alan Scott Status @80@ => closed
Powered by Mantis Bugtracker
