0011300 | VTK | (No Category) | public | 2010-10-07 13:20 | 2016-08-12 09:55 | ||||
Reporter | Ben Medina | ||||||||
Summary | 0011300: vtkGlyph3DMapper does not allow re-use of glyph sources | ||||||||
Description | vtkGlyph3DMapper does not allow you to switch among multiple sources, using SetSourceConnection. You can switch once, but after that, it does not render the correct source. Sample code that demonstrates the issue is attached. To expose the issue, #define REUSE_SOURCES. If you don't define that, the rendering is correct. The workaround, as demonstrated in the sample, is to recreate the glyph sources each time you want to switch glyphs. But this should be unnecessary and could potentially be expensive. | ||||||||
Attached Files | main.cpp [^] (2,080 bytes) 2010-10-07 13:20 | ||||||||
(0037204) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2010-10-07 13:20 | Ben Medina | New Issue | |
2010-10-07 13:20 | Ben Medina | File Added: main.cpp | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037204 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
