0011070 | ParaView | Bug | public | 2010-07-29 23:22 | 2010-12-07 18:10 | ||||
Assigned To | Robert Maynard | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0011070: Crash client/server when plugins don't match | ||||||||
Description | Linux, remote servers (4), trunk. Special setup of ParaView: * Client - Go into lib/paraview3.9. Edit .plugins. Turn on the following plugins: Moments, pvblot, PointSprite_Plugin, and H5PartReader. * Server - Have nothing in the lib/paraview3.9/plugins directory. OK, start ParaView client/ remote server. Open can.exo. All vars on. Apply. Crash. I suppose this could be put off until 3.10 if a fix isn't simple, but we would need to document this VERY LOUDLY somewhere - maybe the wiki? It took some time to figure out what it was. This bug has been around since 3.8.0. | ||||||||
Attached Files | mismatchedPluginsScreenshot.png [^] (80,397 bytes) 2010-12-01 20:01
Relationships | ||||||
(0023054) Utkarsh Ayachit (administrator) 2010-11-08 09:32 |
A solution would be after a client connects to the server, it checks if all plugin requirements are satisfied, if not, it should popup a dialog letting the user know that he should go to the plugin manager and ensure proper server side plugins are loaded before doing anything. To developer: this can be easily implemented as a 'behavior'. |
(0023173) Robert Maynard (developer) 2010-11-11 10:10 |
Now when connecting to a server if a mismatch between the two machines plugins are detected the plugin dialog will spawn to show the user they have an issue. |
(0023655) Alan Scott (manager) 2010-12-01 20:00 |
This doesn't seem to work for me. There are two possible problems - 1) When plugins are turned on and match, this failure screen comes up, and 2) there are plugins that only exist on one side or the other, and these are causing the error screen to come up. To replicate, add the following to .plugins in your bin directory of the client (building the H5 reader, blot and PointSprite_Plugin): <?xml version="1.0"?> <Plugins> <Plugin name="Moments" auto_load="1"/> <Plugin name="PrismServerPlugin" auto_load="0"/> <Plugin name="PrismClientPlugin" auto_load="0"/> <Plugin name="PointSprite_Plugin" auto_load="1"/> <Plugin name="pvblot" auto_load="1"/> <Plugin name="SierraPlotTools" auto_load="0"/> <Plugin name="SLACTools" auto_load="0"/> <Plugin name="SurfaceLIC" auto_load="0"/> <Plugin name="H5PartReader" auto_load="1"/> <Plugin name="AnalyzeReader" auto_load="0"/> <Plugin name="AnalyzeWriter" auto_load="0"/> <Plugin name="NIfTIReader" auto_load="0"/> <Plugin name="NIfTIWriter" auto_load="0"/> </Plugins> Then, on the server side, lib/paraview3.9/plugins directory, add soft links as follows: ln -s ../libPointSprite_Plugin.so libPointSprite_Plugin.so ln -s ../libMoments.so libMoments.so ln -s ../libH5PartReader.so libH5PartReader.so I will attach what I get in the error screen as a screenshot. |
(0023666) Ken Moreland (manager) 2010-12-02 10:20 |
I understand the first problem; the failure screen should certainly not come up if the plugins match. (In fact, this sounds like bug 0010666.) I don't think I understand the second problem. When the plugin does not exist on the server side, it seems to me that the behavior, bringing up the error screen, is the exact right thing to do. It's telling you that there is a plugin mismatch (which there is) and that needs to be addressed (probably by finding the plugin somewhere on the server side). What behavior do you expect? |
(0023676) Alan Scott (manager) 2010-12-02 15:05 |
OK, my bad. Number 2 above results in a hang. |
(0023697) Robert Maynard (developer) 2010-12-03 11:18 |
I have fixed bug 10666. |
(0023708) Robert Maynard (developer) 2010-12-03 16:31 |
with bug 10666 fixed I do believe the feedback issues have been resolved. |
(0023784) Alan Scott (manager) 2010-12-07 18:10 |
Pretty sure this is fixed. If there are nuances, lets write up that specific case. Tested remote server, windows client, trunk. |
2010-07-29 23:22 | Alan Scott | New Issue | |
2010-09-01 11:37 | Utkarsh Ayachit | Priority | high => normal |
2010-09-01 11:37 | Utkarsh Ayachit | Target Version | 3.8.1 => 3.10.shortlist |
2010-11-08 09:32 | Utkarsh Ayachit | Note Added: 0023054 | |
2010-11-08 09:32 | Utkarsh Ayachit | Status | backlog => tabled |
2010-11-08 09:32 | Utkarsh Ayachit | Assigned To | => Robert Maynard |
2010-11-11 10:10 | Robert Maynard | Note Added: 0023173 | |
2010-11-11 10:10 | Robert Maynard | Status | tabled => @80@ |
2010-11-11 10:10 | Robert Maynard | Fixed in Version | => 3.10.shortlist |
2010-11-11 10:10 | Robert Maynard | Resolution | open => fixed |
2010-12-01 15:31 | Utkarsh Ayachit | Fixed in Version | 3.10.shortlist => 3.10 |
2010-12-01 20:00 | Alan Scott | Note Added: 0023655 | |
2010-12-01 20:00 | Alan Scott | Status | @80@ => @20@ |
2010-12-01 20:00 | Alan Scott | Resolution | fixed => reopened |
2010-12-01 20:01 | Alan Scott | File Added: mismatchedPluginsScreenshot.png | |
2010-12-02 10:20 | Ken Moreland | Note Added: 0023666 | |
2010-12-02 10:21 | Ken Moreland | Relationship added | parent of 0010666 |
2010-12-02 15:05 | Alan Scott | Note Added: 0023676 | |
2010-12-02 15:05 | Alan Scott | Status | @20@ => tabled |
2010-12-03 11:18 | Robert Maynard | Note Added: 0023697 | |
2010-12-03 16:31 | Robert Maynard | Note Added: 0023708 | |
2010-12-03 16:31 | Robert Maynard | Status | tabled => @80@ |
2010-12-03 16:31 | Robert Maynard | Resolution | reopened => fixed |
2010-12-07 18:10 | Alan Scott | Note Added: 0023784 | |
2010-12-07 18:10 | Alan Scott | Status | @80@ => closed |
