0011068 | ParaView | Feature | public | 2010-07-29 20:45 | 2010-10-27 20:49 | ||||
Assigned To | Sebastien Jourdain | ||||||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0011068: toolbar that calls macros | ||||||||
Description | We should add the ability to create a toolbar, with buttons that just call python scripts. This could do such things as Read in a file in wireframe mode, or wireframe mode, cull front faces. | ||||||||
Relationships | ||||||
(0022343) Sebastien Jourdain (manager) 2010-09-24 16:10 |
It was already the case |
(0022504) Alan Scott (manager) 2010-10-15 20:53 |
I don't see either how to do this, or where it is documented on the Wiki. Mind giving me some directions? Thanks! |
(0022658) Sebastien Jourdain (manager) 2010-10-22 10:01 |
commit d37a8cd2233b59747c285a4a348ef4952997768e Merge: f5f9a47 2d052f1 Author: Sebastien Jourdain <sebastien.jourdain@kitware.com> Date: Fri Oct 22 09:52:11 2010 -0400 Merge topic 'python-trace-ui' 2d052f1 Change strategy around Python trace usage commit 2d052f1d9ba54bbdee6cc9b89bbb8f01095adf39 Author: Sebastien Jourdain <sebastien.jourdain@kitware.com> Date: Fri Oct 22 09:43:19 2010 -0400 Change strategy around Python trace usage Now the user can only start/stop trace. When the user stop a trace, the Python editor Popup with the content of the trace. The user has to choose what he wants to do with it. He can discard it, save it as a file or save it as a Macro. Caution: As only one editor is used for Python code editing inside ParaView. If the user do not save its trace and re-run another one, when it stop it, the editor will be reset to the later trace content. The same thing happen when you try to edit a Macro while the editor is open. |
(0022720) Alan Scott (manager) 2010-10-27 20:49 |
Excellent. Tested local server, Windows, trunk. |
2010-07-29 20:45 | Alan Scott | New Issue | |
2010-09-01 11:16 | Utkarsh Ayachit | Target Version | 3.10 => 3.10.shortlist |
2010-09-01 11:17 | Utkarsh Ayachit | Relationship added | related to 0001672 |
2010-09-01 11:17 | Utkarsh Ayachit | Relationship deleted | related to 0001672 |
2010-09-01 11:17 | Utkarsh Ayachit | Relationship added | related to 0009672 |
2010-09-20 14:33 | Utkarsh Ayachit | Status | backlog => tabled |
2010-09-20 14:33 | Utkarsh Ayachit | Assigned To | => Sebastiennn Jourdain |
2010-09-24 16:10 | Sebastien Jourdain | Note Added: 0022343 | |
2010-09-24 16:10 | Sebastien Jourdain | Status | tabled => @80@ |
2010-09-24 16:10 | Sebastien Jourdain | Fixed in Version | => 3.10 |
2010-09-24 16:10 | Sebastien Jourdain | Resolution | open => fixed |
2010-10-15 20:53 | Alan Scott | Note Added: 0022504 | |
2010-10-15 20:53 | Alan Scott | Status | @80@ => @20@ |
2010-10-15 20:53 | Alan Scott | Resolution | fixed => reopened |
2010-10-22 10:01 | Sebastien Jourdain | Note Added: 0022658 | |
2010-10-22 10:01 | Sebastien Jourdain | Status | @20@ => @80@ |
2010-10-22 10:01 | Sebastien Jourdain | Resolution | reopened => fixed |
2010-10-27 20:49 | Alan Scott | Note Added: 0022720 | |
2010-10-27 20:49 | Alan Scott | Status | @80@ => closed |
