0011066 | ParaView | Bug | public | 2010-07-29 20:12 | 2010-11-08 18:49 | ||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0011066: Cth files not selected correctly | ||||||||
Description | The CTH folks say that we should use the CTH reader for all files that start with spct. Evidentally this is currently not the case, and is causing problems. Obviously, please don't put the 3.8.1 release at risk. | ||||||||
(0021566) Utkarsh Ayachit (administrator) 2010-07-29 21:56 |
I have to defer this till 3.10 since this requires that we start testing filenames not merely extensions and that may be considerable effort. |
(0021567) Alan Scott (manager) 2010-07-29 21:57 |
I agree. |
(0022811) Utkarsh Ayachit (administrator) 2010-11-02 21:49 |
commit 86f9058c35eeb9d0b293473bc2404c7f1d8b5712 Merge: d199ca2 1c38bec Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Nov 2 21:48:51 2010 -0400 Merge topic 'extended_filename_patterns' 1c38bec Fixed pattern for spcth reader to use filename_pattern and not extension. e723923 Fixed the filter generation to not assume extensions only. |
(0023091) Alan Scott (manager) 2010-11-08 18:49 |
Tested local server, Windows, trunk. |
2010-07-29 20:12 | Alan Scott | New Issue | |
2010-07-29 21:56 | Utkarsh Ayachit | Note Added: 0021566 | |
2010-07-29 21:56 | Utkarsh Ayachit | Target Version | 3.8.1 => 3.10 |
2010-07-29 21:57 | Alan Scott | Note Added: 0021567 | |
2010-09-01 11:16 | Utkarsh Ayachit | Target Version | 3.10 => 3.10.shortlist |
2010-11-02 21:49 | Utkarsh Ayachit | Note Added: 0022811 | |
2010-11-02 21:49 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-11-02 21:49 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
2010-11-02 21:49 | Utkarsh Ayachit | Resolution | open => fixed |
2010-11-02 21:49 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-11-08 18:49 | Alan Scott | Note Added: 0023091 | |
2010-11-08 18:49 | Alan Scott | Status | @80@ => closed |
