0011053 | ParaView | Feature | public | 2010-07-28 16:45 | 2016-08-12 09:58 | ||||
Summary | 0011053: Click to select a block in composite dataset | ||||||||
Description | When dealing with multiblock datasets, we want to extend the "click to select" to be able to select a block. So, we can say "Alt+Click" selects a block. We should expose a setting in the settings dialog allowing users to make selection of block be the default for click-to-select. So for users who typically just deal with "layers" in a single dataset, can work in that mode by default. | ||||||||
Relationships | ||||||
(0037862) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-07-28 16:45 | Utkarsh Ayachit | New Issue | |
2010-07-28 16:46 | Utkarsh Ayachit | Relationship added | parent of 0011054 |
2010-07-28 16:46 | Utkarsh Ayachit | Relationship deleted | parent of 0011054 |
2010-07-28 16:46 | Utkarsh Ayachit | Relationship added | child of 0011054 |
2010-09-01 11:33 | Utkarsh Ayachit | Target Version | 3.10 => 3.10.shortlist |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037862 | |
2016-08-12 09:58 | Kitware Robot | Status | expired => closed |
