0011052 | VTK | (No Category) | public | 2010-07-28 12:48 | 2013-04-05 20:13 | ||||
Reporter | Mike Jackson | ||||||||
Assigned To | Marcus D. Hanwell | ||||||||
Priority | normal | Severity | block | Reproducibility | always | ||||
Summary | 0011052: Compile Error with Clang on vtkPlotStacked.cxx | ||||||||
Description | There are several functions declared in an anonymous namespace in the vtkPlotBar.cxx source file. CopyToPointsSwitch() CopyToPoints() CopyToPoints() Since these functions are not declared anywhere else and CopyToPointsSwitch() calls CopyToPoints() the CopyToPointsSwitch() needs to be declared AFTER the CopyToPoints() functions. Here is the clang error. /Users/Shared/OpenSource/VTK/Charts/vtkPlotBar.cxx:62:5: error: use of undeclared identifier 'CopyToPoints' vtkTemplateMacro( ^ In file included from /Users/Shared/OpenSource/VTK/Charts/vtkPlotBar.cxx:16: In file included from /Users/Shared/OpenSource/VTK/Charts/vtkPlotBar.h:25: In file included from /Users/Shared/OpenSource/VTK/Charts/vtkPlot.h:24: In file included from /Users/Shared/OpenSource/VTK/Charts/vtkContextItem.h:25: In file included from /Users/Shared/OpenSource/VTK/Charts/vtkAbstractContextItem.h:27: In file included from /Users/Shared/OpenSource/VTK/Common/vtkObject.h:42: /Users/Shared/OpenSource/VTK/Common/vtkSetGet.h:663:3: note: instantiated from: vtkTemplateMacroCase(VTK_DOUBLE, double, call); \ ^ /Users/Shared/OpenSource/VTK/Charts/vtkPlotBar.cxx:62:5: note: instantiated from: vtkTemplateMacro( ^ /Users/Shared/OpenSource/VTK/Charts/vtkPlotBar.cxx:63:9: note: instantiated from: CopyToPoints(points,previous_points, a, static_cast<VTK_TT*>(b->GetVoidPointer(0)), n)); ^ This is with 535:[mjackson@ferb:Build]$ clang --version clang version 2.8 (trunk 109582) Target: x86_64-apple-darwin9 Thanks Thread model: posix | ||||||||
(0021520) Mike Jackson (reporter) 2010-07-28 12:49 |
This also effects vtkPlotBar.cxx |
(0021522) Mike Jackson (reporter) 2010-07-28 12:56 |
This also effects vtkPlotPoints.cxx |
(0021532) Marcus D. Hanwell (developer) 2010-07-28 16:42 |
Commit fb29df2 addresses the issues you pointed out. I can't seem to teach clang how to find some of my system headers here (specifically iostream.h) despite adding system include paths to the source file indicated, and so I was not able to verify the build continued. I will see if I can get clang working locally at some point soon. |
2010-07-28 12:48 | Mike Jackson | New Issue | |
2010-07-28 12:49 | Mike Jackson | Note Added: 0021520 | |
2010-07-28 12:56 | Mike Jackson | Note Added: 0021522 | |
2010-07-28 14:05 | Marcus D. Hanwell | Status | backlog => tabled |
2010-07-28 14:05 | Marcus D. Hanwell | Assigned To | => Marcus D. Hanwell |
2010-07-28 16:42 | Marcus D. Hanwell | Note Added: 0021532 | |
2010-07-28 16:42 | Marcus D. Hanwell | Status | tabled => @80@ |
2010-07-28 16:42 | Marcus D. Hanwell | Resolution | open => fixed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
2013-04-05 20:13 | Berk Geveci | Status | customer review => closed |
