0010908 | ParaView | Feature | public | 2010-06-29 10:31 | 2011-09-01 13:31 | ||||
Reporter | Sven Buijssen | ||||||||
Priority | normal | Severity | feature | Reproducibility | N/A | ||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0010908: Update labels of reader objects in pipeline browser when replacing files while loading state file | ||||||||
Description | commit 8f3fe99a23c9fdb74cff7d3c2a374fa157239c68 added dialog to prompt to change filenames while loading a state file. Currently, the labels displayed in the pipeline browser are preserved, regardless whether one replaces or keeps the file names stored in the state file. That does make sense if a user has altered it prior to saving a state file, i.e. display name != basename(file name). But in case the user hasn't, it would be very convenient if the label in the pipeline browser would get updated with the new file name. Maybe it is best to let the user decide by presenting him a checkbox in the change filename dialog. | ||||||||
(0021668) Utkarsh Ayachit (administrator) 2010-08-05 13:52 |
Qt/Components/pqFixStateFilenamesDialog is the dialog that gets popped up when a state file is loaded. In this dialog, in the constructor, the state xml is parsed and a data-structure is created that has the reader-xml dom elements. These are then later updated when the filename is changed by the user. In the state xml all source proxies (include readers) are present in xml as follows: ... <ProxyCollection name="sources"> <Item id="136" name="Sphere1"/> .... </ProxyCollection> ... The name here is the name that the source/reader shows up as in the GUI. Now the parsing code will have to locate and keep track of these elements associated with the reader. So when the filename changes, it can update the registration name as well. |
(0022325) David Partyka (developer) 2010-09-22 17:46 |
This should be fixed on master in commit d62df76b9d6ae7fc0dee403ea2770d95106e9147. Please report if there are any more issues. |
(0022505) Alan Scott (manager) 2010-10-15 21:02 |
Trusting Utkarsh. |
2010-06-29 10:31 | Sven Buijssen | New Issue | |
2010-08-05 13:45 | Utkarsh Ayachit | Status | backlog => tabled |
2010-08-05 13:45 | Utkarsh Ayachit | Assigned To | => David Partyka |
2010-08-05 13:52 | Utkarsh Ayachit | Note Added: 0021668 | |
2010-09-22 17:46 | David Partyka | Note Added: 0022324 | |
2010-09-22 17:46 | David Partyka | Note Deleted: 0022324 | |
2010-09-22 17:46 | David Partyka | Note Added: 0022325 | |
2010-09-22 17:46 | David Partyka | Status | tabled => @80@ |
2010-09-22 17:46 | David Partyka | Fixed in Version | => Development |
2010-09-22 17:46 | David Partyka | Resolution | open => fixed |
2010-10-15 21:02 | Alan Scott | Note Added: 0022505 | |
2010-10-15 21:02 | Alan Scott | Status | @80@ => closed |
2011-09-01 13:31 | Utkarsh Ayachit | Fixed in Version | Development => 3.12 |
