0010775 | ParaView | Bug | public | 2010-05-28 14:39 | 2010-10-15 20:21 | ||||
Reporter | jhgoebbert | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Product Version | 3.8 | ||||||||
Target Version | Fixed in Version | 3.8.1 | |||||||
Summary | 0010775: XDMF-Reader and hdf5-hyperslabs = segfault | ||||||||
Description | Hi, since 3.8.0 (tested with Linux-x86 binary version) it is not possible to use hyperslabs in XDMF-files. The following attributes result in a segfault in libXDMF of paraview. An example is attached <Attribute Active="1" Type="Scalar" Center="Node" Name="u_with_hyperslab"> <DataItem ItemType="HyperSlab" Dimensions="8 8 8"> <DataItem Dimensions="3 3" Format="XML"> 0 0 0 1 1 1 8 8 8 </DataItem> <DataItem ItemType="Uniform" Format="HDF" NumberType="Float" Precision="8" Dimensions="8 8 8"> test.h5:/u </DataItem> </DataItem> </Attribute> | ||||||||
Additional Information | backtrace: *** glibc detected *** /opt/nfsimport/paraview/paraview-3.8.0/lib/paraview-3.8/paraview-real: free(): invalid pointer: 0x00007fff3219cf00 *** ======= Backtrace: ========= /lib64/libc.so.6[0x3dd82722ef] /lib64/libc.so.6(cfree+0x4b)[0x3dd827273b] /opt/nfsimport/paraview/paraview-3.8.0/lib/paraview-3.8/libXdmf.so(_ZN12XdmfDataItem25UpdateInformationFunctionEv+0x31)[0x2ae170ee6871] /opt/nfsimport/paraview/paraview-3.8.0/lib/paraview-3.8/libvtkXdmf.so(_ZN16vtkXdmfHeavyData13ReadAttributeEP13XdmfAttributeiPi+0xa1)[0x2ae16e7880a1] /opt/nfsimport/paraview/paraview-3.8.0/lib/paraview-3.8/libvtkXdmf.so(_ZN16vtkXdmfHeavyData14ReadAttributesEP10vtkDataSetP8XdmfGridPi+0xc2)[0x2ae16e78a892] /opt/nfsimport/paraview/paraview-3.8.0/lib/paraview-3.8/libvtkXdmf.so(_ZN16vtkXdmfHeavyData16RequestImageDataEP8XdmfGridb+0x2ad)[0x2ae16e78b17d] /opt/nfsimport/paraview/paraview-3.8.0/lib/paraview-3.8/libvtkXdmf.so(_ZN16vtkXdmfHeavyData15ReadUniformDataEP8XdmfGrid+0x1b4)[0x2ae16e78c044] /opt/nfsimport/paraview/paraview-3.8.0/lib/paraview-3.8/libvtkXdmf.so(_ZN16vtkXdmfHeavyData8ReadDataEv+0x27c)[0x2ae16e78cb5c] /opt/nfsimport/paraview/paraview-3.8.0/lib/paraview-3.8/libvtkXdmf.so(_ZN13vtkXdmfReader11RequestDataEP14vtkInformationPP20vtkInformationVectorS3_+0x220)[0x2ae16e78e670] | ||||||||
Attached Files | XDMF-hyperslab-bug-example.zip [^] (938 bytes) 2010-05-28 14:39 XdmfDataItem-patch.diff [^] (628 bytes) 2010-06-07 12:14 [Show Content] hyperslab_bugfix.patch [^] (440 bytes) 2010-06-14 09:09 [Show Content] | ||||||||
(0020932) Miguel Fosas (reporter) 2010-06-07 12:14 |
The patch attached should fix the problem. Although I don't know the details of the Xdmf library, these changes solved the problem for me. |
(0021000) jhgoebbert (reporter) 2010-06-14 09:11 |
Kenji Takizawas patch fixes the problem, too. The patch is added as "hyperslab_bugfix.patch". This patch should already be applied to trunk (as far as I know). |
(0022389) jhgoebbert (reporter) 2010-09-30 04:41 |
This bug is fixed in 3.8.1 Please set "status" to "closed". |
(0022393) David Partyka (developer) 2010-09-30 10:47 |
User reports this is no longer an issue in 3.8.1 |
(0022500) Alan Scott (manager) 2010-10-15 20:21 |
Closed as per reporter. |
2010-05-28 14:39 | jhgoebbert | New Issue | |
2010-05-28 14:39 | jhgoebbert | File Added: XDMF-hyperslab-bug-example.zip | |
2010-06-07 12:14 | Miguel Fosas | Note Added: 0020932 | |
2010-06-07 12:14 | Miguel Fosas | File Added: XdmfDataItem-patch.diff | |
2010-06-14 09:09 | jhgoebbert | File Added: hyperslab_bugfix.patch | |
2010-06-14 09:11 | jhgoebbert | Note Added: 0021000 | |
2010-06-14 10:05 | David Partyka | Status | backlog => tabled |
2010-06-14 10:05 | David Partyka | Assigned To | => David Partyka |
2010-09-30 04:41 | jhgoebbert | Note Added: 0022389 | |
2010-09-30 10:47 | David Partyka | Note Added: 0022393 | |
2010-09-30 10:47 | David Partyka | Status | tabled => @80@ |
2010-09-30 10:47 | David Partyka | Fixed in Version | => 3.8.1 |
2010-09-30 10:47 | David Partyka | Resolution | open => fixed |
2010-10-15 20:21 | Alan Scott | Note Added: 0022500 | |
2010-10-15 20:21 | Alan Scott | Status | @80@ => closed |
