0010708 | VTK | (No Category) | public | 2010-05-12 09:40 | 2014-10-05 15:07 | ||||
Reporter | xabi riobe | ||||||||
Assigned To | Cory Quammen | ||||||||
Target Version | Fixed in Version | 6.2.0 | |||||||
Summary | 0010708: vtkMapper::InterpolateScalarsBeforeMappingOn interfers with 2D actor | ||||||||
Description | In the following example there is a cube with scalars on the PointData, and a lut is applied to its mapper. There is also a line with a 2D actor in the scene. If InterpolateScalarsBeforeMappingOn is not called on the cube's mapper, the line is correctly red, but if it is called, then it looks like the cube lut is interferring with the rendering of the line. And if there is more 2D actors, the first one that is added to the renderer always presents the same problem. | ||||||||
Additional Information | picture good.png shows the line correctly rendered in red when InterpolateScalarsBeforeMapping is Off on the cube's mapper. picture bad.png shows the wrong rendering of the line when InterpolateScalarsBeforeMapping is On. | ||||||||
Attached Files | ColorBug.cpp [^] (5,044 bytes) 2010-05-12 09:40 good.png [^] (5,598 bytes) 2010-05-12 09:41 bad.png [^] (5,609 bytes) 2010-05-12 09:41 ColorBug-6.0.cpp [^] (5,009 bytes) 2013-09-30 03:46 | ||||||||
(0030902) Jean-Christophe Fillion-Robin (manager) 2013-06-05 14:24 |
Does the problem still occur with VTK 5.10 ? VTK 6 ? |
(0031655) xabi riobe (reporter) 2013-09-30 03:48 |
The problem is still there with VTK 5.10 and VTK 6.0 I updated the example code to be used with 6.0 |
(0033561) Cory Quammen (developer) 2014-10-02 21:35 |
Possible fix with test here: http://review.source.kitware.com/#/t/4792/ [^] |
(0033585) Cory Quammen (developer) 2014-10-05 15:07 |
Fix in commit 37259c004230d1a96994f6c702591198828602c8 Author: Cory Quammen <cory.quammen@kitware.com> Date: Thu Oct 2 21:30:03 2014 -0400 BUG 10708: Fix vtkPolyDataMapper2D color mapping If another actor in the scene enabled GL_TEXTURE_2D and the vtkPolyDataMapper2D's input had a texture coordinate attribute, the vtkPolyDataMapper2D would apply the texture map while mapping the input. Fix by disabling GL_TEXTURE_2D if ScalarVisbility is off. Change-Id: I187cafe3bebe03082be04e0f65b140f3f6b3ad67 |
2010-05-12 09:40 | xabi riobe | New Issue | |
2010-05-12 09:40 | xabi riobe | File Added: ColorBug.cpp | |
2010-05-12 09:41 | xabi riobe | File Added: good.png | |
2010-05-12 09:41 | xabi riobe | File Added: bad.png | |
2012-03-07 04:09 | xabi riobe | Status | expired => backlog |
2012-03-07 04:09 | xabi riobe | Resolution | open => reopened |
2013-06-05 14:24 | Jean-Christophe Fillion-Robin | Note Added: 0030902 | |
2013-09-30 03:46 | xabi riobe | File Added: ColorBug-6.0.cpp | |
2013-09-30 03:48 | xabi riobe | Note Added: 0031655 | |
2014-10-02 21:35 | Cory Quammen | Note Added: 0033561 | |
2014-10-02 21:35 | Cory Quammen | Assigned To | => Cory Quammen |
2014-10-02 21:35 | Cory Quammen | Status | backlog => gerrit review |
2014-10-05 15:07 | Cory Quammen | Note Added: 0033585 | |
2014-10-05 15:07 | Cory Quammen | Status | gerrit review => closed |
2014-10-05 15:07 | Cory Quammen | Resolution | reopened => fixed |
2014-10-05 15:07 | Cory Quammen | Fixed in Version | => 6.2.0 |
