0010671 | ParaView | Bug | public | 2010-05-04 12:54 | 2010-11-16 18:41 | ||||
Reporter | David Partyka | ||||||||
Product Version | 3.8 | ||||||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0010671: VisTrails should not be built if Qt is not enabled. | ||||||||
Description | This is with QT off, mpi on, python on Not asking you to fix it, just making you aware ... CMake Error at Plugins/VisTrails/CMakeLists.txt:32 (INCLUDE): include called with wrong number of arguments. Include only takes one file. CMake Error at Plugins/VisTrails/CMakeLists.txt:49 (INCLUDE): include called with wrong number of arguments. Include only takes one file. CMake Error at Plugins/VisTrails/CMakeLists.txt:52 (QT4_WRAP_CPP): Unknown CMake command "QT4_WRAP_CPP". ############### Turn off vistrails plugin == solution | ||||||||
(0023153) David Partyka (developer) 2010-11-10 17:08 |
This plugin is now built by PARAVIEW_EXTERNAL_PLUGINS_FILE and this won't be built unless it is deliberately included by the developer. |
(0023322) Alan Scott (manager) 2010-11-16 18:41 |
Agree with what Dave said. |
2010-05-04 12:54 | David Partyka | New Issue | |
2010-05-04 12:54 | David Partyka | Status | backlog => tabled |
2010-05-04 12:54 | David Partyka | Assigned To | => David Partyka |
2010-11-10 17:08 | David Partyka | Note Added: 0023153 | |
2010-11-10 17:08 | David Partyka | Status | tabled => @80@ |
2010-11-10 17:08 | David Partyka | Fixed in Version | => 3.10 |
2010-11-10 17:08 | David Partyka | Resolution | open => fixed |
2010-11-16 18:41 | Alan Scott | Note Added: 0023322 | |
2010-11-16 18:41 | Alan Scott | Status | @80@ => closed |
