0010650 | ParaView | Bug | public | 2010-04-30 11:56 | 2010-07-07 17:08 | ||||
Target Version | 3.8.1 | Fixed in Version | 3.8.1 | ||||||
Summary | 0010650: Time related issues with loading state with after changing the data file in the state | ||||||||
Description | * Save a pvsm with a timeseries. * Edit the pvsm to point to a new file with a different number of timesteps * load the state * The animation still preserves old timesteps, even if the user didn't explicitly set them before. If the user explicitly sets the end times, they need to preserved, of course. | ||||||||
(0020490) Utkarsh Ayachit (administrator) 2010-04-30 12:09 |
commit 37d7ca1c97b35759c14de7ce903e6e2cb71cfb08 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Apr 30 12:06:31 2010 -0400 Fixed BUG 0010650. Issues with loading states. When a state file was loaded with a changed data file that had a different set of timesteps that the one when the state was saved, the application still preserved the old timesteps. Fixed that by: * not loading states for information properties. * after state is loaded triggering callbacks from timekeeper so that animation scene and others update the time ranges to override those from the state when acceptable i.e. user didn't explicitly set them (detectable by the lock properties). |
(0020566) Alan Scott (manager) 2010-05-04 18:29 |
Assuming correct, since I don't have two files with different number of time steps that have the same variable names. |
(0021297) Utkarsh Ayachit (administrator) 2010-07-07 17:08 |
moved to release branch |
2010-04-30 11:56 | Utkarsh Ayachit | New Issue | |
2010-04-30 12:09 | Utkarsh Ayachit | Note Added: 0020490 | |
2010-04-30 12:09 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-04-30 12:09 | Utkarsh Ayachit | Fixed in Version | => 3.8.2 |
2010-04-30 12:09 | Utkarsh Ayachit | Resolution | open => fixed |
2010-04-30 12:09 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-05-04 18:29 | Alan Scott | Note Added: 0020566 | |
2010-05-04 18:29 | Alan Scott | Status | @80@ => closed |
2010-06-15 09:44 | Utkarsh Ayachit | Target Version | 3.8.2 => 3.8.1 |
2010-06-15 09:45 | Utkarsh Ayachit | Fixed in Version | 3.8.2 => 3.8.1 |
2010-07-07 09:55 | Utkarsh Ayachit | Fixed in Version | 3.8.1 => Development |
2010-07-07 10:03 | Utkarsh Ayachit | Note Added: 0021270 | |
2010-07-07 17:08 | Utkarsh Ayachit | Note Deleted: 0021270 | |
2010-07-07 17:08 | Utkarsh Ayachit | Note Added: 0021297 | |
2010-07-07 17:08 | Utkarsh Ayachit | Fixed in Version | Development => 3.8.1 |
