0001057 | VTK | (No Category) | public | 2004-08-13 06:36 | 2016-08-12 09:54 | ||||
Reporter | ak | ||||||||
Assigned To | Dave DeMarle | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0001057: Read error on double data in simple float file | ||||||||
Description | I get Generic Warning: In /home/bottoms/stage/vtk-4.2.6/IO/vtkDataReader.cxx, line 833Error reading ascii data! using the Debian version 4.2.6-2 of VTK under the following circumstances: 1. a file has a scalar point lookup table of type float 2. some of the data in the file is written with more than float precision (for example, the number 1e-100 occurs) The file reads just fine if I change the data type to "double". An illustration of this can be found in the file at http://www.stud.uni-karlsruhe.de/~uj6g/result.vtk. [^] (written using PyVTK, just load into MayaVi or Paraview to see the error) | ||||||||
Attached Files | ,,result.vtk [^] (98,658 bytes) 1969-12-31 19:00 | ||||||||
(0001369) ak (reporter) 2004-08-13 06:56 |
Added file at URL as attachment. |
(0001379) Mathieu Malaterre (developer) 2004-08-16 13:06 |
No crash occurs, changing severity |
(0030934) Jean-Christophe Fillion-Robin (manager) 2013-06-05 17:05 |
Using paraview 3.8.0, the following warning is reported: Generic Warning: In /home/kitware/Dashboard/MyTests/ParaView-3-8/ParaView-3.8/ParaView/VTK/IO/vtkDataReader.cxx, line 1382 Error reading ascii data. Possible mismatch of datasize with declaration. |
(0030936) Jean-Christophe Fillion-Robin (manager) 2013-06-05 17:06 |
Is this still an issue for you ? I propose we close the issue. |
(0031208) Dave DeMarle (administrator) 2013-07-22 19:04 |
If the bug is still present in 6.0, please reopen. |
(0036745) Kitware Robot (administrator) 2016-08-12 09:54 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2008-11-30 09:25 | Mathieu Malaterre | Assigned To | Mathieu Malaterre => David Cole |
2011-01-19 10:17 | David Cole | Assigned To | David Cole => |
2013-06-05 17:05 | Jean-Christophe Fillion-Robin | Note Added: 0030934 | |
2013-06-05 17:06 | Jean-Christophe Fillion-Robin | Note Added: 0030936 | |
2013-07-22 19:04 | Dave DeMarle | Note Added: 0031208 | |
2013-07-22 19:04 | Dave DeMarle | Status | backlog => expired |
2013-07-22 19:04 | Dave DeMarle | Assigned To | => Dave DeMarle |
2016-08-12 09:54 | Kitware Robot | Note Added: 0036745 | |
2016-08-12 09:54 | Kitware Robot | Status | expired => closed |
2016-08-12 09:54 | Kitware Robot | Resolution | open => moved |
