0010567 | ParaView | Bug | public | 2010-04-16 10:36 | 2010-05-04 20:03 | ||||
Reporter | David Partyka | ||||||||
Product Version | 3.8 | ||||||||
Target Version | Fixed in Version | 3.8 | |||||||
Summary | 0010567: Fix building Ogg/Theora on Solaris | ||||||||
Description | I'd like to suggest a patch to be able to easily compile ParaView 3.8.0 RC1 on SPARC Solaris (SunOS 5.10, using self-compiled GCC 4.3.4 64bit) with Ogg/Theora support enabled (-DVTK_USE_OGGTHEORA_ENCODER:BOOL=ON). Currently, that fails with > /usr/ccs/bin/ld: illegal option -- version-script=/data/PV3.8.0RC1/VTK/Utilities/vtkoggtheora/vtkoggtheora.vscript > usage: ld [-6:abc:d:e:f:h:il:mo:p:rstu:z:B:CD:F:GI:L:M:N:P:Q:R:S:VY:?] file(s) > [-64] enforce a 64-bit link-edit > [-a] create an absolute file > [-b] do not do special PIC relocations in a.out > [-B direct | nodirect] > establish direct bindings, or inhibit direct binding > to, the object being created > [-B dynamic | static] > search for shared libraries|archives > [-B eliminate] eliminate unqualified global symbols from the > symbol table > [...] According to the ld man page, the option --version-script is only meaningful on ELF platforms anyway, no wonder Solaris ld bails out. With kind regards, Sven | ||||||||
Additional Information | From c58d34b6b5a27b6626335d0493f1b9d33b575cef Mon Sep 17 00:00:00 2001 From: Sven Buijssen <sven.buijssen@tu-dortmund.de> Date: Wed, 14 Apr 2010 13:01:24 +0200 Subject: [PATCH] COMP: Avoid command line option incompatible with Sun ld on Sun OS. --- VTK/Utilities/vtkoggtheora/CMakeLists.txt | 10 +++++++--- 1 files changed, 7 insertions(+), 3 deletions(-) diff --git a/VTK/Utilities/vtkoggtheora/CMakeLists.txt b/VTK/Utilities/vtkoggtheora/CMakeLists.txt index 2059c2c..b455c38 100644 --- a/VTK/Utilities/vtkoggtheora/CMakeLists.txt +++ b/VTK/Utilities/vtkoggtheora/CMakeLists.txt @@ -126,12 +126,16 @@ IF(APPLE) "-read_only_relocs suppress -Wl,-exported_symbols_list,${VTKOGGTHEORA_SOURCE_DIR}/vtkoggtheora.exp" ) ENDIF(APPLE) -# assume that -Wl,--version-script works on UNIX systems (excluding Mac and Cygwin). +# assume that -Wl,--version-script works on UNIX systems (excluding Mac, Cygwin and Solaris SPARC). # otherwise the user can always set to an empty string IF(UNIX AND NOT APPLE AND NOT CYGWIN) - SET( VTKOGGTHEORA_SHARED_LINKER_FLAGS - "-Wl,--version-script=${VTKOGGTHEORA_SOURCE_DIR}/vtkoggtheora.vscript" + IF("${CMAKE_SYSTEM_NAME}" MATCHES "SunOS") + SET( VTKOGGTHEORA_SHARED_LINKER_FLAGS "" ) + ELSE("${CMAKE_SYSTEM_NAME}" MATCHES "SunOS") + SET( VTKOGGTHEORA_SHARED_LINKER_FLAGS + "-Wl,--version-script=${VTKOGGTHEORA_SOURCE_DIR}/vtkoggtheora.vscript" ) + ENDIF("${CMAKE_SYSTEM_NAME}" MATCHES "SunOS") ENDIF(UNIX AND NOT APPLE AND NOT CYGWIN) SET(VTKOGGTHEORA_SHARED_LINKER_FLAGS "${VTKOGGTHEORA_SHARED_LINKER_FLAGS}" CACHE STRING "Additional linker flags for vtkoggtheora when building as a shared library" -- 1.7.0.3 | ||||||||
(0020424) David Partyka (developer) 2010-04-26 22:27 |
Fixed on master and release in 6f980cffa591e273a514a4ea4cdaf27cd1ff864c. |
(0020574) Alan Scott (manager) 2010-05-04 20:03 |
Trusting that this does fix builds on SunOS, since I don't have access to this OS. |
2010-04-16 10:36 | David Partyka | New Issue | |
2010-04-16 10:36 | David Partyka | Status | backlog => tabled |
2010-04-16 10:36 | David Partyka | Assigned To | => David Partyka |
2010-04-26 22:27 | David Partyka | Note Added: 0020424 | |
2010-04-26 22:27 | David Partyka | Status | tabled => @80@ |
2010-04-26 22:27 | David Partyka | Fixed in Version | => 3.8 |
2010-04-26 22:27 | David Partyka | Resolution | open => fixed |
2010-05-04 20:03 | Alan Scott | Note Added: 0020574 | |
2010-05-04 20:03 | Alan Scott | Status | @80@ => closed |
