0010566 | ParaView | Bug | public | 2010-04-16 10:06 | 2010-04-26 18:53 | ||||
Reporter | David Partyka | ||||||||
Product Version | 3.8 | ||||||||
Target Version | Fixed in Version | 3.8 | |||||||
Summary | 0010566: pvblot plugin should not be built if python is not enabled | ||||||||
Description | Email from the list: Paul, you are correct, the plugin should not be built if PARAVIEW_ENABLE_PYTHON is OFF. Dave, can we make sure that the plugin in OFF if PARAVIEW_ENABLE_PYTHON is OFF? One reliable way would be to simply add and IF(PARAVIEW_ENABLE_PYTHON) block around the entire CMakeLists.txt in Plugins/pvblot. | ||||||||
(0020396) David Partyka (developer) 2010-04-26 00:10 |
Fixed in 08a95d27791142e4d75f30f950f2d211250b846d |
(0020411) Alan Scott (manager) 2010-04-26 18:53 |
Trusting that it was done correctly. |
2010-04-16 10:06 | David Partyka | New Issue | |
2010-04-16 10:06 | David Partyka | Status | backlog => tabled |
2010-04-16 10:06 | David Partyka | Assigned To | => David Partyka |
2010-04-26 00:10 | David Partyka | Note Added: 0020396 | |
2010-04-26 00:10 | David Partyka | Status | tabled => @80@ |
2010-04-26 00:10 | David Partyka | Fixed in Version | => 3.8 |
2010-04-26 00:10 | David Partyka | Resolution | open => fixed |
2010-04-26 18:53 | Alan Scott | Note Added: 0020411 | |
2010-04-26 18:53 | Alan Scott | Status | @80@ => closed |
