0010565 | ParaView | Bug | public | 2010-04-16 10:04 | 2011-01-17 11:44 | ||||
Reporter | Paul Melis | ||||||||
Assigned To | Dave DeMarle | ||||||||
Product Version | 3.8 | ||||||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0010565: Manta plugin not fully installed by "make install" | ||||||||
Description | With 3.8 RC1 and enabling the manta plugin Although "make install" nicely copies libMantaView.so to the install location, libvtkMantaCS.so and libvtkManta.so are left behind. This prohibits the plugin from being loaded after installation. | ||||||||
(0020434) Dave DeMarle (administrator) 2010-04-27 13:10 |
This fix appears to work. Waiting for dashboards before asking for merge into RC2. Note - Manta itself is not installed, so you still have to make sure the Manta build/lib is on the library search path or the plugin won't load, complaining about not finding lib for Manta_Factory. commit 05211f75e2c2ca4e8456a2a63191ecb77c50ce7d Author: Dave DeMarle <dave.demarle@kitware.com> Date: Tue Apr 27 13:04:49 2010 -0400 BUG:0010565 install VTK level vtkManta libraries with plugin. |
(0024762) Alan Scott (manager) 2011-01-17 11:44 |
Trusting Dave that this should be closed. |
2010-04-16 10:04 | Paul Melis | New Issue | |
2010-04-16 10:51 | David Partyka | Status | backlog => tabled |
2010-04-16 10:51 | David Partyka | Assigned To | => Dave DeMarle |
2010-04-27 13:10 | Dave DeMarle | Note Added: 0020434 | |
2011-01-14 13:54 | Utkarsh Ayachit | Status | tabled => @80@ |
2011-01-14 13:54 | Utkarsh Ayachit | Resolution | open => fixed |
2011-01-14 13:55 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
2011-01-17 11:44 | Alan Scott | Note Added: 0024762 | |
2011-01-17 11:44 | Alan Scott | Status | @80@ => closed |
