0010512 | ParaView | Bug | public | 2010-04-05 19:44 | 2011-01-13 17:00 | ||||
Priority | urgent | Severity | major | Reproducibility | have not tried | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0010512: Calculator misbehaves on composite data | ||||||||
Description | The calculator is misbehaving on composite data. Given a composite data set with a vector field that exists in multiple blocks, the calculator does not operate correctly on the field in all blocks. Instead, it provides the calculation in the first block only and then outputs a cryptic message about outdated variables for every other block. To replicate the error, do the following: 1. Create a Hierarchical Fractal source. Apply. 2. Add a calculator filter. Set the expression to pass any one of the vector field variables (cell data VectorXYZ or point data coords). Apply. You will get a bunch of error messages, and the Result array will be partial and only defined on level 1. | ||||||||
(0020078) Utkarsh Ayachit (administrator) 2010-04-06 10:34 |
Not sure what the weird logic was supposed to do. All we really needed was to re-populate the variables for the calculator in RequestData(). /cvsroot/ParaView3/ParaView3/VTK/Common/vtkFunctionParser.cxx,v <-- VTK/Common/vtkFunctionParser.cxx new revision: 1.46; previous revision: 1.45 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkArrayCalculator.cxx,v <-- VTK/Graphics/vtkArrayCalculator.cxx new revision: 1.51; previous revision: 1.50 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkArrayCalculator.h,v <-- VTK/Graphics/vtkArrayCalculator.h new revision: 1.23; previous revision: 1.22 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVArrayCalculator.cxx,v <-- Servers/Filters/vtkPVArrayCalculator.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVArrayCalculator.h,v <-- Servers/Filters/vtkPVArrayCalculator.h new revision: 1.2; previous revision: 1.1 |
(0020079) Ken Moreland (manager) 2010-04-06 10:55 |
Looks like the problem is fixed. Please make sure to push this fix to the 3.8 branch. |
(0020083) Utkarsh Ayachit (administrator) 2010-04-06 17:31 |
It's been committed to 3.8 branch as well (as per Dave P.) |
2010-04-05 19:44 | Ken Moreland | New Issue | |
2010-04-05 19:45 | Ken Moreland | Status | backlog => tabled |
2010-04-05 19:45 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2010-04-06 10:34 | Utkarsh Ayachit | Note Added: 0020078 | |
2010-04-06 10:34 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-04-06 10:34 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-04-06 10:34 | Utkarsh Ayachit | Resolution | open => fixed |
2010-04-06 10:55 | Ken Moreland | Note Added: 0020079 | |
2010-04-06 17:31 | Utkarsh Ayachit | Note Added: 0020083 | |
2010-04-06 17:49 | Ken Moreland | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 |
