0010487 | VTK | (No Category) | public | 2010-03-30 09:27 | 2016-08-12 09:55 | ||||
Reporter | Eric Monson | ||||||||
Assigned To | Jeff Baumes | ||||||||
Platform | Mac & Linux | OS | 10.6 & Ubuntu 9.10 | OS Version | |||||
Summary | 0010487: Hardware Selector gives unreliable results with textured polygons | ||||||||
Description | I was creating a vtkIcicleView with textured polygons, but started to see weird selection behavior depending on the texture image I was using. Finally I figured out that the Hardware Selector reports inconsistent cell IDs when the texture image is too dark. With white around the periphery (on my Mac with Cocoa and CVS VTK it only needs to be a one-pixel white border) the selector works fine. As the image gets darker it starts to report erroneous IDs. When the image is too dark it can't "see" any polys at all. | ||||||||
Steps To Reproduce | I'm attaching a zip file which contains a Python script and four PNG images to show the effect. This was the simplest example I could come up with to reproduce the problem using "off the shelf" VTK. You need to set the path for the images and VTK source in the script, and then uncomment which image you want to use for the test. Then, you click on the rectangles of the icicle view (not really using vtkIcicleView here, just a pipeline and a vtkRenderView) and look at the terminal for a printout of the cell IDs that the hardware selector reports. The comments at the beginning of the script summarize what you should see: # IDs in tree should be (and are reported with Good image as): # # 0 0 0 0 0 0 0 0 0 # 1 2 3 4 4 4 8 9 10 # 5 6 7 # Unreliable reports them as: # # 0 0 0 0 0 0 0 0 0 # 0 1 2 3 3 3 6 6 7 # 3 4 5 # Bad can't see any nodes to select at all | ||||||||
Attached Files | HardwareSelectorTest.zip [^] (28,756 bytes) 2010-03-30 09:27 | ||||||||
(0037157) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2010-03-30 09:27 | Eric Monson | New Issue | |
2010-03-30 09:27 | Eric Monson | File Added: HardwareSelectorTest.zip | |
2010-03-30 10:19 | Jeff Baumes | Status | backlog => tabled |
2010-03-30 10:19 | Jeff Baumes | Assigned To | => Jeff Baumes |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037157 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
