0010470 | ParaView | Bug | public | 2010-03-26 15:28 | 2016-08-12 09:58 | ||||
Reporter | Dave DeMarle | ||||||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0010470: image data delivered to client looses all but the active scalars which results in bad things | ||||||||
Description | connect to a parallel server make sure rendering is on client side make mandelbrot apply any filter that adds new point arrays ex process id scalars, calculator filter w RESULT=coordsX switch to color by iterations problem is that when root node of server executes vtkImageAppend to merge all of the satellites data into one, it strips all but one of the arrays (and replaces the active scalar array with a 0 length array with no name.) It then sends that to the client, which doesn't know what to do and you get error messages. | ||||||||
(0020018) Dave DeMarle (administrator) 2010-03-26 16:17 |
Should be able to fix it by iterating over all arrays, setting each to be the active one, then calling append to merge that array, and inserting the result into the output, in turn. |
(0021159) Dave DeMarle (administrator) 2010-06-24 16:35 |
This was fixed in the master and submitted for inclusion in 3.8.1 |
(0037800) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-03-26 15:28 | Dave DeMarle | New Issue | |
2010-03-26 16:17 | Dave DeMarle | Note Added: 0020018 | |
2010-06-01 13:04 | Dave DeMarle | Status | backlog => tabled |
2010-06-01 13:04 | Dave DeMarle | Assigned To | => Dave DeMarle |
2010-06-24 16:35 | Dave DeMarle | Note Added: 0021159 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037800 | |
2016-08-12 09:58 | Kitware Robot | Status | expired => closed |
