0010445 | ParaView | Bug | public | 2010-03-20 16:24 | 2010-07-07 16:58 | ||||
Reporter | Jerome Velut | ||||||||
Assigned To | user3172 | ||||||||
Platform | i686 | OS | Linux | OS Version | Fedora-12 | ||||
Target Version | 3.8.1 | Fixed in Version | 3.8.1 | ||||||
Summary | 0010445: Background color is not memorized for 3D View | ||||||||
Description | Changing the background color in 3D view works well. But going back to the "View settings" seems to put the default background color back. | ||||||||
Steps To Reproduce | - Set a 3D view as active - Choose "View settings" either from the Edit menu or from the view toolbar - Change the background color - Ok - Go back to "View Settings" -> the background color proposed is the default one. - Change, for instance, the "Use Parallel Projection" state and press OK -> the projection changed, but the background is back to default. | ||||||||
(0020328) Jerome Velut (reporter) 2010-04-21 06:11 |
This bug remains in the ParaView-3.9 git repo (SHA1 commit id: c5f3c079ec12a1a85526a56e40147ded8089b7f0) |
(0020625) Jerome Velut (reporter) 2010-05-06 14:33 |
[From wascott on the mailing list] This bug still exists, and is actually obnoxious. Furthermore, there is another twist to it - you cannot reset the background color by just saying Edit/ View Settings/ General/ Restore Default/ OK. |
(0020645) user3172 2010-05-07 14:02 |
git commit id: 41c4af6ef3b55c43f528b732e859c648d22334d3 |
(0020806) Alan Scott (manager) 2010-05-21 13:14 |
Fixed on trunk. Tested local server, trunk, Windows. |
(0021292) Utkarsh Ayachit (administrator) 2010-07-07 16:58 |
moved commits to release branch |
2010-03-20 16:24 | Jerome Velut | New Issue | |
2010-04-21 06:11 | Jerome Velut | Note Added: 0020328 | |
2010-05-06 07:52 | Utkarsh Ayachit | Status | backlog => tabled |
2010-05-06 07:52 | Utkarsh Ayachit | Assigned To | => user3172 |
2010-05-06 14:33 | Jerome Velut | Note Added: 0020625 | |
2010-05-07 14:02 | user3172 | Note Added: 0020645 | |
2010-05-07 14:02 | user3172 | Fixed in Version | => Development |
2010-05-07 14:02 | user3172 | Target Version | => 3.8.2 |
2010-05-11 15:08 | user3172 | Status | tabled => @80@ |
2010-05-11 15:08 | user3172 | Resolution | open => fixed |
2010-05-21 13:14 | Alan Scott | Note Added: 0020806 | |
2010-05-21 13:14 | Alan Scott | Status | @80@ => closed |
2010-06-15 09:44 | Utkarsh Ayachit | Target Version | 3.8.2 => 3.8.1 |
2010-07-07 10:51 | Utkarsh Ayachit | Note Added: 0021279 | |
2010-07-07 16:56 | Utkarsh Ayachit | Note Deleted: 0021279 | |
2010-07-07 16:58 | Utkarsh Ayachit | Note Added: 0021292 | |
2010-07-07 16:58 | Utkarsh Ayachit | Fixed in Version | Development => 3.8.1 |
