0010390 | ParaView | Bug | public | 2010-03-08 19:01 | 2011-01-13 17:00 | ||||
Reporter | Burlen | ||||||||
Assigned To | Marcus D. Hanwell | ||||||||
Target Version | Fixed in Version | 3.8 | |||||||
Summary | 0010390: feenableexcept and PGI 9.0.4 compiler | ||||||||
Description | Compiling PV with pgi 9.0.4 on Cray Xt5 the build dies as follows. "/nics/c/home/bloring/ParaView/ParaView3/VTK/Common/vtkFloatingPointExceptions.cxx", line 54: error: identifier "feenableexcept" is undefined feenableexcept(FE_DIVBYZERO | FE_INVALID); ^ "/nics/c/home/bloring/ParaView/ParaView3/VTK/Common/vtkFloatingPointExceptions.cxx", line 74: error: identifier "fedisableexcept" is undefined fedisableexcept(FE_DIVBYZERO | FE_INVALID); ^ 2 errors detected in the compilation of "/nics/c/home/bloring/ParaView/ParaView3/VTK/Common/vtkFloatingPointExceptions.cxx". make[2]: *** [VTK/Common/CMakeFiles/vtkCommon.dir/vtkFloatingPointExceptions.cxx.o] Error 2 "fenv.h" says: 117 118 #ifdef __USE_GNU 119 120 /* Enable individual exceptions. Will not enable more exceptions than 121 EXCEPTS specifies. Returns the previous enabled exceptions if all 122 exceptions are successfully set, otherwise returns -1. */ 123 extern int feenableexcept (int __excepts) __THROW; 124 125 /* Disable individual exceptions. Will not disable more exceptions than 126 EXCEPTS specifies. Returns the previous enabled exceptions if all 127 exceptions are successfully disabled, otherwise returns -1. */ 128 extern int fedisableexcept (int __excepts) __THROW; 129 130 /* Return enabled exceptions. */ 131 extern int fegetexcept (void) __THROW; 132 #endif 133 | ||||||||
(0019806) Marcus D. Hanwell (developer) 2010-03-10 11:03 |
This should be fixed in CVS, VTK/Common/CMakeLists.txt 1.235 contains the fix. Pat Marion verified it compiled correctly on the Cray with the PGI compiler. Please reopen if this is not the case. |
(0019829) Alan Scott (manager) 2010-03-10 22:16 |
Tested by Pat. See notes above. Closed. |
2010-03-08 19:01 | Burlen | New Issue | |
2010-03-09 16:46 | Marcus D. Hanwell | Status | backlog => tabled |
2010-03-09 16:46 | Marcus D. Hanwell | Assigned To | => Marcus D. Hanwell |
2010-03-10 11:03 | Marcus D. Hanwell | Note Added: 0019806 | |
2010-03-10 11:03 | Marcus D. Hanwell | Status | tabled => @80@ |
2010-03-10 11:03 | Marcus D. Hanwell | Fixed in Version | => 3.8 |
2010-03-10 11:03 | Marcus D. Hanwell | Resolution | open => fixed |
2010-03-10 22:16 | Alan Scott | Note Added: 0019829 | |
2010-03-10 22:16 | Alan Scott | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 |
