0010386ParaViewBugpublic2010-03-08 15:332011-01-13 17:00
ReporterUtkarsh Ayachit
Assigned ToMarcus D. Hanwell
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.8Fixed in Version3.8
Summary0010386: Marks: Log scale doesn't work for bottom/top axes
DescriptionLog scale doesn't seem to work for bottom or top axes, it works for left/right axes.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0019821)
Marcus D. Hanwell (developer)
2010-03-10 17:13
Working on this - the problem is that log10(0) is -infinity... So I will add treatment of NaN, inf and -inf to the chart rendering code. This may also require some extra logic when dealing with the range of the axes - first pass I will look at the existing code to see what solutions were found.
(0019858)
2010-03-12 11:45
VTK/Charts/vtkPlotLine.cxx 1.23 includes improved handling for inf/nan values. I will mark this issue as resolved, and keep fixes for making the top/right axes work on the other bug report that is open.
(0019994)
Alan Scott (manager)
2010-03-23 21:47
We now have logs top and bottom. Note that there is a known issue with log of 0, still being worked on.
 Issue History
2010-03-08 15:33 Utkarsh Ayachit New Issue
2010-03-08 15:33 Utkarsh Ayachit Status backlog => tabled
2010-03-08 15:33 Utkarsh Ayachit Assigned To => Marcus D. Hanwell
2010-03-10 17:13 Marcus D. Hanwell Note Added: 0019821
2010-03-12 11:45 Marcus D. Hanwell Note Added: 0019858
2010-03-12 11:45 Marcus D. Hanwell Status tabled => @80@
2010-03-12 11:45 Marcus D. Hanwell Fixed in Version => 3.8
2010-03-12 11:45 Marcus D. Hanwell Resolution open => fixed
2010-03-23 21:47 Alan Scott Note Added: 0019994
2010-03-23 21:47 Alan Scott Status @80@ => closed
2011-01-13 17:00 Source_changeset_attached => VTK master a2bd8391
2011-01-13 17:00 Source_changeset_attached => VTK master 020ef709
