0010349 | VTK | (No Category) | public | 2010-03-01 09:01 | 2014-02-17 14:26 | ||||
Reporter | xabi riobe | ||||||||
Assigned To | Andy Bauer | ||||||||
Target Version | Fixed in Version | 6.1.dev | |||||||
Summary | 0010349: vtkCellLocator precision issue | ||||||||
Description | There is a numerical precision problem with the method vtkCellLocator::IntersectWithLine in vtkCellLocator.cxx in line 287 of revision 1.89: if (cell->IntersectWithLine(a0, a1, tol, t, x, pcoords, subId) ) { if ( ! this->IsInOctantBounds(x) ) sometimes the resulting intersection point returned by the cell->IntersectWithLine is a (0.000000000000004) little out of the bounds and the call to IsInOctantBounds discard the point. I think it will be a good thing to add a tolerance to the method vtkCellLocator::IsInOctantBounds(double x[3]). | ||||||||
Steps To Reproduce | in the attached file there is an example that illustrates the issue. a vtkCellLocator is filled with a cube and a line going from dPoint to dPoint2 intersect the box. in Z axis, the bounds of the box are (1.0; -20) if dPoint2[2] = -77.76333863288239, the resulting intersection point is at -20 and all is correct if dPoint2[2] = -77.76333863288238, the resulting intersection point is at -20.000000000000004, so out of bounds. | ||||||||
Project | TBD | ||||||||
Attached Files | Intersect.cpp [^] (4,183 bytes) 2010-03-01 09:01 locatorbug.cxx [^] (7,930 bytes) 2013-04-25 13:49 | ||||||||
(0030576) Steve Langer (reporter) 2013-04-16 16:53 |
I just ran into the same issue. It causes vtkPicker::Pick to choose the wrong object when resolving mouse clicks on the surface of a grid. A solution would to remove the "if" at line 1242 of vtkCellLocator::BuildLocatorInternal in vtkCellLocator.cxx (version 5.10.1). Always increase the size of the bounding box to ensure that all cells are actually within the box, even if min!=max. This fixes the problem in my situation. |
(0030623) Steve Langer (reporter) 2013-04-25 13:51 |
I uploaded another file that illustrates the problem in a real world situation, distilled from a larger program. There are comments in the file explaining what's going on. |
(0031656) xabi riobe (reporter) 2013-09-30 04:34 |
The problem is still there in 6.0.0 add the following line to Intersect.cpp : #define vtkRenderingCore_AUTOINIT 2(vtkInteractionStyle, vtkRenderingOpenGL) |
(0031681) xabi riobe (reporter) 2013-10-07 10:46 |
http://review.source.kitware.com/#/c/12936/ [^] |
(0031982) Dave DeMarle (administrator) 2013-12-17 13:11 |
proposed patch had problems in gerrit review |
(0032342) Andy Bauer (developer) 2014-02-17 14:26 |
Merged in through gerrit. Commit SHA is 618d6279992e23182093ef683ea25400267a09ce |
2010-03-01 09:01 | xabi riobe | New Issue | |
2010-03-01 09:01 | xabi riobe | File Added: Intersect.cpp | |
2012-03-07 03:57 | xabi riobe | Status | expired => backlog |
2012-03-07 03:57 | xabi riobe | Resolution | open => reopened |
2013-04-16 16:53 | Steve Langer | Note Added: 0030576 | |
2013-04-25 13:49 | Steve Langer | File Added: locatorbug.cxx | |
2013-04-25 13:51 | Steve Langer | Note Added: 0030623 | |
2013-09-30 04:34 | xabi riobe | Note Added: 0031656 | |
2013-10-07 10:46 | xabi riobe | Note Added: 0031681 | |
2013-10-07 10:46 | xabi riobe | Status | backlog => gerrit review |
2013-12-17 13:11 | Dave DeMarle | Note Added: 0031982 | |
2013-12-17 13:11 | Dave DeMarle | Assigned To | => Dave DeMarle |
2013-12-17 13:11 | Dave DeMarle | Status | gerrit review => backlog |
2014-01-14 05:52 | xabi riobe | Status | backlog => gerrit review |
2014-02-17 14:25 | Andy Bauer | Project | => TBD |
2014-02-17 14:25 | Andy Bauer | Type | => incorrect functionality |
2014-02-17 14:25 | Andy Bauer | Assigned To | Dave DeMarle => Andy Bauer |
2014-02-17 14:26 | Andy Bauer | Note Added: 0032342 | |
2014-02-17 14:26 | Andy Bauer | Status | gerrit review => closed |
2014-02-17 14:26 | Andy Bauer | Resolution | reopened => fixed |
2014-02-17 14:26 | Andy Bauer | Fixed in Version | => 6.1.dev |
