0010277 | ParaView | Bug | public | 2010-02-11 10:07 | 2010-07-12 21:26 | ||||
Reporter | Stephane P | ||||||||
Target Version | 3.8.1 | Fixed in Version | 3.8.1 | ||||||
Summary | 0010277: animation cue created in python are not visible in the animation view | ||||||||
Description | when creating animations from python, the cues created and registered in the AnimationScene are not visible in the animation view, and are not saved in the state. | ||||||||
Project | ParaViS | ||||||||
Relationships | ||||||
(0021125) Utkarsh Ayachit (administrator) 2010-06-22 15:13 |
commit 76abe353579e6776f17ecd1f08ada64156f72000 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Jun 21 22:36:40 2010 -0400 Fixed BUG 0009470. Better support for animation in python. * Added API to access the active AnimationScene. * Ensured that a valid animation scene is created when a new connection is made in pvpython. Also ensureing that the Views and TimeKeeper properties on the animation scene and updated correctly. * Added new "Name" property to Property class to allow access to the name of a property. * Added API to access/create animation tracks. |
(0021126) Utkarsh Ayachit (administrator) 2010-06-22 15:14 |
Note that the new API has been added as indicated on the wiki: http://www.paraview.org/Wiki/ParaView/Python_Scripting#Animating [^] Old API will work, but those animation scenes/tracks won't be seen by the GUI. --------------------------------- Sample new-style script: --------------------------------- from paraview.simple import * Sphere() Show() Render() # Get the application-wide animation scene scene = GetAnimationScene() # Get the animation track for animating "StartTheta" on the active source. # GetAnimationTrack() creates a new track if none exists. cue = GetAnimationTrack("StartTheta") # Create 2 keyframes for the StartTheta track keyf0 = CompositeKeyFrame() keyf0.Interpolation = 'Ramp' # At time = 0, value = 0 keyf0.KeyTime = 0 keyf0.KeyValues= [0] keyf1 = CompositeKeyFrame() # At time = 1.0, value = 200 keyf1.KeyTime = 1.0 keyf1.KeyValues= [200] # Add keyframes. cue.KeyFrames = [keyf0, keyf1] scene.Play() |
(0021127) Utkarsh Ayachit (administrator) 2010-06-22 15:14 |
Needs to move to "release" branch |
(0021288) Utkarsh Ayachit (administrator) 2010-07-07 16:44 |
Moved to "release" branch and verified it works on "release" branch |
(0021370) Alan Scott (manager) 2010-07-12 21:26 |
Trusting fixed. |
2010-02-11 10:07 | Stephane P | New Issue | |
2010-06-15 09:35 | Utkarsh Ayachit | Relationship added | related to 0009470 |
2010-06-15 09:35 | Utkarsh Ayachit | Target Version | => 3.8.2 |
2010-06-15 09:44 | Utkarsh Ayachit | Target Version | 3.8.2 => 3.8.1 |
2010-06-21 21:31 | Utkarsh Ayachit | Relationship deleted | related to 0009470 |
2010-06-21 21:31 | Utkarsh Ayachit | Relationship added | child of 0009470 |
2010-06-22 15:12 | Utkarsh Ayachit | Status | backlog => tabled |
2010-06-22 15:12 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-06-22 15:13 | Utkarsh Ayachit | Note Added: 0021125 | |
2010-06-22 15:13 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-06-22 15:13 | Utkarsh Ayachit | Fixed in Version | => 3.8.1 |
2010-06-22 15:13 | Utkarsh Ayachit | Resolution | open => fixed |
2010-06-22 15:14 | Utkarsh Ayachit | Note Added: 0021126 | |
2010-06-22 15:14 | Utkarsh Ayachit | Note Added: 0021127 | |
2010-07-07 09:55 | Utkarsh Ayachit | Fixed in Version | 3.8.1 => Development |
2010-07-07 16:44 | Utkarsh Ayachit | Note Added: 0021288 | |
2010-07-07 16:44 | Utkarsh Ayachit | Fixed in Version | Development => 3.8.1 |
2010-07-12 21:26 | Alan Scott | Note Added: 0021370 | |
2010-07-12 21:26 | Alan Scott | Status | @80@ => closed |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
