0010266 | ParaView | Feature | public | 2010-02-10 08:38 | 2011-08-03 14:22 | ||||
Reporter | Berk Geveci | ||||||||
Assigned To | Robert Maynard | ||||||||
Product Version | 4.0 | ||||||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0010266: Fix progress reporting | ||||||||
Description | Fix progress reporting in parallel and progress reporting on Mac. On Mac, progress reporting does not work with Mac. To fix, we need to make sure that none of widgets cause progress reporting from inside paint. This may require forcing renders before paint happens. For some technical reason I don't understand, it is not possible to update a widget (the progress bar) from inside the paint method of another. | ||||||||
Project | Sandia | ||||||||
(0026884) Robert Maynard (developer) 2011-06-21 13:41 |
Merge topic 'corrected-progress-bar' aae0628 ENH: call processEvents before updating progress. 3537ca1 BUG: Correct a timing issue that progress exposes. 3bf8fa2 COMP: Fixed missing header for Windows compilation. e3e1639 BUG: ProcessEvents shouldn't be called if progress value is zero. 72ef0e5 ENH: Add another signal to when model items state change. dcd5e0a Merge remote branch 'origin/master' into corrected-progress-bar 70c625f Revert "BUG: Prism was presuming every representation input was a pqPipelineSource." 5bec479 BUG: Fixed more signals and slots that didn't work with progress. 1c1d861 BUG: Prism was presuming every representation input was a pqPipelineSource. cb060a1 UpdateDataEvent is now sent after all servers are done processing. 36446fa Corrected a nasty bug when calling processEvents. 0b82857 Merge branch 'updated-progress-bar' into corrected-progress-bar 03bc3a7 Move the call to process events out of widgets. 0fa96e8 Move the testing SHA1 forward for the processEvents method. af0d4c3 Fixed the issue of calling processEvents, by using the testing processEvents. 0fc5592 Found a way to properly show the text without using processEvents(). |
(0026930) Utkarsh Ayachit (administrator) 2011-06-30 14:17 |
For Developers: These issues are slated for gatekeeper review on July 1, 2 pm EDT. |
2010-02-10 08:38 | Berk Geveci | New Issue | |
2011-06-21 13:39 | Robert Maynard | Assigned To | => Robert Maynard |
2011-06-21 13:40 | Robert Maynard | Status | expired => backlog |
2011-06-21 13:41 | Robert Maynard | Status | backlog => todo |
2011-06-21 13:41 | Robert Maynard | Status | todo => active development |
2011-06-21 13:41 | Robert Maynard | Note Added: 0026884 | |
2011-06-21 13:41 | Robert Maynard | Status | active development => gatekeeper review |
2011-06-30 14:17 | Utkarsh Ayachit | Note Added: 0026930 | |
2011-07-01 15:25 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-07-22 14:16 | Utkarsh Ayachit | Project | => Sandia |
2011-07-29 16:18 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
2011-08-03 14:22 | Utkarsh Ayachit | Status | customer review => closed |
2011-08-03 14:22 | Utkarsh Ayachit | Resolution | open => fixed |
