0010253 | ParaView | Bug | public | 2010-02-08 11:41 | 2010-02-22 20:15 | ||||
Reporter | Michael Wild | ||||||||
Priority | normal | Severity | block | Reproducibility | always | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0010253: QVTK must link against QtXmlPatterns | ||||||||
Description | Since QVTK includes headers from QtWebKit which links against QtXmlPatterns. Probably one should also fix FindQt4.cmake to include QtXmlPatterns in the QT_LIBRARIES list, but since it's already out there and used by ParaView, ParaView should work around it. Probably this is only a real problem on Mac OS X with the binary Qt-Distribution by Nokia which uses relative install_name paths for the frameworks, causing the linker to fail when trying to resolve QtXmlPatterns.framework/Versions/4/QtXmlPatterns. This patch adds QT_QTXMLPATTERNS to the libraries QVTK links against: http://github.com/themiwi/ParaView/commit/f2c5d7e0b065a232a54ebb39f516122cc854b6a2 [^] | ||||||||
(0019475) Michael Wild (reporter) 2010-02-08 11:42 |
Forgot to mention that this is with current ParaView-CVS, Qt-Cocoa-4.6.1 obtained from Nokia (binary installer) and Mac OS X 10.6.2. |
(0019477) Utkarsh Ayachit (administrator) 2010-02-08 12:55 |
Reminder sent to: David Partyka Dave, Can you check this out? Thanks. |
(0019501) David Partyka (developer) 2010-02-09 14:51 |
Patch Applied. Thanks! |
(0019587) Alan Scott (manager) 2010-02-22 20:15 |
Untested. Assuming that patch writer and developer checked each other. |
2010-02-08 11:41 | Michael Wild | New Issue | |
2010-02-08 11:42 | Michael Wild | Note Added: 0019475 | |
2010-02-08 12:54 | Utkarsh Ayachit | Status | backlog => tabled |
2010-02-08 12:54 | Utkarsh Ayachit | Assigned To | => David Partyka |
2010-02-08 12:54 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-02-08 12:55 | Utkarsh Ayachit | Note Added: 0019477 | |
2010-02-09 14:51 | David Partyka | Note Added: 0019501 | |
2010-02-09 14:57 | David Partyka | Resolution | open => fixed |
2010-02-09 15:49 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-02-09 15:49 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-02-22 20:15 | Alan Scott | Note Added: 0019587 | |
2010-02-22 20:15 | Alan Scott | Status | @80@ => closed |
