0010224 | ParaView | Bug | public | 2010-02-01 16:38 | 2010-11-16 17:47 | ||||
Reporter | user3172 | ||||||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0010224: enabling MPI and enabling parallel support for HDF5 causes compile time errors for H5PartReader | ||||||||
Description | When enabled MPI support and parallel support for HDF5 caused compilation errors for H5PartReader plugin. There are two issues. 1. Missing include path for the MPI in Plugins/H5PartReader 2. Missing preprocessor macro H5PART_HAS_MPI option in the cmake in order to build the plugin. | ||||||||
(0023300) David Partyka (developer) 2010-11-16 13:15 |
I applied the appropriate CMake changes as you described to get it to build with mpi enabled hdf5. |
(0023310) Alan Scott (manager) 2010-11-16 17:47 |
Trusting Dave. Please reopen if this is still a problem. |
2010-02-01 16:38 | user3172 | New Issue | |
2010-11-11 09:32 | David Partyka | Status | backlog => tabled |
2010-11-11 09:32 | David Partyka | Assigned To | => David Partyka |
2010-11-16 13:15 | David Partyka | Note Added: 0023300 | |
2010-11-16 13:15 | David Partyka | Status | tabled => @80@ |
2010-11-16 13:15 | David Partyka | Fixed in Version | => 3.10 |
2010-11-16 13:15 | David Partyka | Resolution | open => fixed |
2010-11-16 17:47 | Alan Scott | Note Added: 0023310 | |
2010-11-16 17:47 | Alan Scott | Status | @80@ => closed |
