0010132 | ParaView | Bug | public | 2010-01-12 21:51 | 2010-01-21 17:28 | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0010132: Cube axis does not follow color conventions for print | ||||||||
Description | Cube axis does not work with print palette. ParaView 3.6.2, XP, local server. * Sources/ sphere. * Display/ cube axis. * Edit/ Settings/ Colors. Change Palette to print palette. Note that the Axis colors are still WHITE! Makes cube axis unusable, thus I am marking high priority for 3.8. | ||||||||
(0019228) Utkarsh Ayachit (administrator) 2010-01-20 16:39 |
CubeAxes color is now linked with the "Foreground" color. /cvsroot/ParaView3/ParaView3/Qt/Components/pqCubeAxesEditorDialog.cxx,v <-- Qt/Components/pqCubeAxesEditorDialog.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqCubeAxesEditorDialog.ui,v <-- Qt/Components/Resources/UI/pqCubeAxesEditorDialog.ui new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- Qt/Core/pqPipelineRepresentation.cxx new revision: 1.52; previous revision: 1.51 |
(0019252) Alan Scott (manager) 2010-01-21 17:28 |
Excellent. Tested local server, XP, trunk. |
2010-01-12 21:51 | Alan Scott | New Issue | |
2010-01-20 16:39 | Utkarsh Ayachit | Note Added: 0019228 | |
2010-01-20 16:39 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-01-20 16:39 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-01-20 16:39 | Utkarsh Ayachit | Resolution | open => fixed |
2010-01-20 16:39 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-01-21 17:28 | Alan Scott | Note Added: 0019252 | |
2010-01-21 17:28 | Alan Scott | Status | @80@ => closed |
