0010105 | ParaView | Bug | public | 2010-01-08 04:54 | 2011-01-13 17:00 | ||||
Reporter | Stephane P | ||||||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0010105: surface with edge representation does color the surface if data has both surface and lines | ||||||||
Description | if the data is composed of both 2D and 3D cells, the Surface With Edge representation applies the solid color to the surface even if a "color by" field is chosen. To reproduce the bug, load the given state file, apply the Surface With Edge representation to the AppendDatasets1 entry, and choose color by RTData --> the surface color is the solid color. | ||||||||
Project | ParaViS | ||||||||
Attached Files | bug_surface+edge.pvsm [^] (219,417 bytes) 2010-01-08 04:54 | ||||||||
(0019703) Utkarsh Ayachit (administrator) 2010-03-03 17:12 |
Restoring state of texture enable flag as well after rendering edges. /cvsroot/ParaView3/ParaView3/VTK/Rendering/vtkOpenGLRepresentationPainter.cxx,v <-- VTK/Rendering/vtkOpenGLRepresentationPainter.cxx new revision: 1.11; previous revision: 1.10 |
(0019787) Alan Scott (manager) 2010-03-09 21:47 |
Tested local client, XP, trunk. Excellent writeup of this bug. |
2010-01-08 04:54 | Stephane P | New Issue | |
2010-01-08 04:54 | Stephane P | File Added: bug_surface+edge.pvsm | |
2010-03-03 16:43 | Utkarsh Ayachit | Status | backlog => tabled |
2010-03-03 16:43 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-03-03 16:43 | Utkarsh Ayachit | Priority | normal => high |
2010-03-03 16:43 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-03-03 17:12 | Utkarsh Ayachit | Note Added: 0019703 | |
2010-03-03 17:12 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-03-03 17:12 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-03-03 17:12 | Utkarsh Ayachit | Resolution | open => fixed |
2010-03-09 21:47 | Alan Scott | Note Added: 0019787 | |
2010-03-09 21:47 | Alan Scott | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
