0010101 | ParaView | Bug | public | 2010-01-06 16:22 | 2010-12-07 16:27 | ||||
Assigned To | Robert Maynard | ||||||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0010101: file browser unclear for multiple timesteps in exodus files | ||||||||
Description | I tested loading exodus files that have different time steps in each separate file. It works fine. However, these file names do not display properly in the file browser. The following are examples of what needs to read cleanly Serial run with no mesh modifications: basename.e Parallel run with no mesh modifications: basename.e.2.0 basename.e.2.1 Serial run with mesh modifications: basename.e basename.e-s0001 basename.e-s0002 basename.e-s0003 Parallel run with mesh modifications: basename.e.2.0 basename.e.2.1 basename.e-s0001.2.0 basename.e-s0001.2.1 basename.e-s0002.2.0 basename.e-s0002.2.1 basename.e-s0003.2.0 basename.e-s0003.2.1 I have an example dataset (named mesh_mod_exodus.tar.gz). Please ask me for it if necessary. | ||||||||
(0023703) Utkarsh Ayachit (administrator) 2010-12-03 16:16 |
Robert, can you check if this one is fixed already? |
(0023738) Robert Maynard (developer) 2010-12-06 10:58 |
Fixed the pqFileDialogFilter to accept multiple digit extension as a valid file series. So now file like below are valid. basename.e.1.0.1 basename.e.1.0.2 basename.e.1.0.3 Also added in support for -s to be a valid delimiter for file extensions so that basename.e-s.1.0 is also valid. Commit SHA1: b79ea6f470b72f8 |
(0023774) Alan Scott (manager) 2010-12-07 16:26 |
It appears as though this fixes this bug. I tested .e-s.number, as well as .e-snumber. The second is what is output by Sierra. |
(0023775) Alan Scott (manager) 2010-12-07 16:27 |
Tested local server, Windows client, trunk. |
2010-01-06 16:22 | Alan Scott | New Issue | |
2010-04-16 01:56 | Utkarsh Ayachit | Target Version | 3.8 => 3.10 |
2010-12-03 16:16 | Utkarsh Ayachit | Assigned To | => Robert Maynard |
2010-12-03 16:16 | Utkarsh Ayachit | Status | backlog => tabled |
2010-12-03 16:16 | Utkarsh Ayachit | Note Added: 0023703 | |
2010-12-03 16:16 | Utkarsh Ayachit | Target Version | 3.10 => 3.10.shortlist |
2010-12-06 10:58 | Robert Maynard | Note Added: 0023738 | |
2010-12-06 10:58 | Robert Maynard | Status | tabled => @80@ |
2010-12-06 10:58 | Robert Maynard | Fixed in Version | => 3.10 |
2010-12-06 10:58 | Robert Maynard | Resolution | open => fixed |
2010-12-07 16:26 | Alan Scott | Note Added: 0023774 | |
2010-12-07 16:27 | Alan Scott | Note Added: 0023775 | |
2010-12-07 16:27 | Alan Scott | Status | @80@ => closed |
