0010062 | ParaView | Feature | public | 2009-12-17 16:03 | 2010-03-17 16:36 | ||||
Priority | immediate | Severity | major | Reproducibility | always | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0010062: Changes to rescale data range | ||||||||
Description | As per a discussion with Utkarsh, for ParaView 3.8.0, we will deal with setting the data range as follows: There will be 3 options, user selectable on one of the settings dialogs. Setting is sticky - i.e., ParaView remembers users preference between runs. * Set data range using the LAST time step. (This will be the default.) * Set data range using the CURRENT time step. (Since ParaView will bring up the first time step, this will effectively be the First time step). * Set data range to update every time step. A forth option will be made available. It will run the Temporal Statistics filter under the covers, and update the data range for ALL time steps. This option will be a new button, either on the "Active Variable Controls" toolbar, and/or on the Color Scale Editor. Thus, it will only be activated explicitly by the user every time this action is desired. | ||||||||
Relationships | |||||||||||
(0018958) Ken Moreland (manager) 2009-12-21 10:08 |
In ParaView3/Plugins/SLACTools there is a filter called vtkPTemporalRanges that finds the min/max of all values over all time. (In contrast, the temporal statistics filter fins the min/max of each point/cell over time.) If this is convenient, you should move the filter out of the plugin for more general use. |
(0019043) Utkarsh Ayachit (administrator) 2010-01-06 10:49 |
Partial fix for BUG 0010062. * Added API to vtkSMOutputPort to get temporal data information i.e. information about array ranges over time. * Added button to ColorScaleEditor to let the user scale the LUT to set the temporal range for the array. * Adding new vtkPVTemporalDataInformation which accumulates DataInformation over all timesteps in the data. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMOutputPort.h,v <-- Servers/ServerManager/vtkSMOutputPort.h new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMOutputPort.cxx,v <-- Servers/ServerManager/vtkSMOutputPort.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Servers/Common/CMakeLists.txt,v <-- Servers/Common/CMakeLists.txt new revision: 1.101; previous revision: 1.100 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVTemporalDataInformation.h,v <-- Servers/Common/vtkPVTemporalDataInformation.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVTemporalDataInformation.cxx,v <-- Servers/Common/vtkPVTemporalDataInformation.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.h,v <-- Qt/Core/pqPipelineRepresentation.h new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- Qt/Core/pqPipelineRepresentation.cxx new revision: 1.48; previous revision: 1.47 /cvsroot/ParaView3/ParaView3/Qt/Core/pqOutputPort.h,v <-- Qt/Core/pqOutputPort.h new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Core/pqOutputPort.cxx,v <-- Qt/Core/pqOutputPort.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDataRepresentation.h,v <-- Qt/Core/pqDataRepresentation.h new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDataRepresentation.cxx,v <-- Qt/Core/pqDataRepresentation.cxx new revision: 1.11; previous revision: 1.10 |
(0019049) Utkarsh Ayachit (administrator) 2010-01-07 13:37 |
/cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarsToColors.h,v <-- Qt/Core/pqScalarsToColors.h new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarsToColors.cxx,v <-- Qt/Core/pqScalarsToColors.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- Qt/Core/pqPipelineRepresentation.cxx new revision: 1.49; previous revision: 1.48 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqApplicationOptions.ui,v <-- Qt/Components/Resources/UI/pqApplicationOptions.ui new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationOptions.cxx,v <-- Qt/Components/pqApplicationOptions.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/ApplicationComponents/pqDataTimeStepBehavior.cxx,v <-- Qt/ApplicationComponents/pqDataTimeStepBehavior.cxx new revision: 1.2; previous revision: 1.1 |
(0019064) Alan Scott (manager) 2010-01-08 15:46 |
Excellent. Note that instead of adding an update every time step, you added a grow every time step (kind of a run temporal statistics filter). Please add a forth option - update every time step. |
(0019944) Alan Scott (manager) 2010-03-17 16:36 |
Tested local server. XP, trunk. We are going to take this as finished. If anyone wants us to change the min and max each timestep, we will open up a new bug. |
2009-12-17 16:03 | Alan Scott | New Issue | |
2009-12-21 10:08 | Ken Moreland | Note Added: 0018958 | |
2010-01-04 15:57 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-01-04 15:57 | Utkarsh Ayachit | Status | backlog => tabled |
2010-01-04 15:57 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-01-06 10:49 | Utkarsh Ayachit | Note Added: 0019043 | |
2010-01-07 13:37 | Utkarsh Ayachit | Note Added: 0019049 | |
2010-01-07 13:37 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-01-07 13:37 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-01-07 13:37 | Utkarsh Ayachit | Resolution | open => fixed |
2010-01-08 15:46 | Alan Scott | Note Added: 0019064 | |
2010-01-08 15:46 | Alan Scott | Status | @80@ => tabled |
2010-01-18 22:32 | Alan Scott | Relationship added | has duplicate 0009920 |
2010-01-18 22:35 | Alan Scott | Relationship added | duplicate of 0005360 |
2010-02-01 14:23 | Utkarsh Ayachit | Priority | high => immediate |
2010-03-17 16:36 | Alan Scott | Note Added: 0019944 | |
2010-03-17 16:36 | Alan Scott | Status | tabled => closed |
