MantisBT - ParaView
View Issue Details
0009028ParaViewBugpublic2009-05-14 09:032013-05-18 20:00
Ken Moreland
Marcus D. Hanwell
normalminorhave not tried
closedfixed
NeedsVerification4.0
Sandia
incorrect functionality
0009028: Plots interpolate to invalid points
The Plot Over Line filter creates a special column in its output called vtkValidPointMask that is a flag to the plot view to specify that the given point has no data and therefore should not be drawn. When the point is invalid, the rest of the columns are filled with zero for no particular consequence since these values will not be viewed. (Should they have NAN instead?)
The problem is that in the XY plot when you have a valid point next to an invalid point, it interpolates between the valid point. This creates inappropriate lines to the 0 axis. To see this problem in action, do the following.
1. Load disk_out_ref.ex2, load Temp variable, Apply.
2. Note that the range of Temp goes from 293 to 913. This is in Kelvins, so it never gets near zero.
3. Plot Over Line. Apply.
The default line for the plot starts outside the mesh, goes inside, back outside, back inside, and then outside for a final time. This is reflected by the two distinct regions in the plot. However, notice that at the ends of each contiguous region there is a line drawn down to 0. Those lines should not be there. The data never goes to 0 and therefore we should not be drawing lines to 0.
No tags attached.
Issue History
2009-05-14 09:03Ken MorelandNew Issue
2009-06-03 10:34Utkarsh AyachitStatusbacklog => tabled
2009-06-03 10:34Utkarsh AyachitAssigned To => Julien Finet
2009-06-17 08:14Julien FinetNote Added: 0016733
2009-06-17 10:51Julien FinetNote Edited: 0016733
2011-01-28 13:54Utkarsh AyachitAssigned ToJulien Finet => Marcus D. Hanwell
2011-01-28 13:54Utkarsh AyachitTarget Version3.8 => NeedsVerification
2011-01-28 14:02Marcus D. HanwellNote Added: 0025139
2011-01-31 10:03Ken MorelandNote Added: 0025176
2011-01-31 10:11Marcus D. HanwellNote Added: 0025177
2011-01-31 10:29Ken MorelandNote Added: 0025179
2011-01-31 10:34Marcus D. HanwellNote Added: 0025180
2013-01-08 21:31Alan ScottProject => Sandia
2013-01-08 21:31Alan ScottType => incorrect functionality
2013-05-03 14:03Utkarsh AyachitNote Added: 0030691
2013-05-03 14:03Utkarsh AyachitStatusbacklog => gatekeeper review
2013-05-03 14:03Utkarsh AyachitResolutionopen => fixed
2013-05-10 08:23Utkarsh AyachitFixed in Version => git-master
2013-05-10 08:23Utkarsh AyachitStatusgatekeeper review => customer review
2013-05-10 08:23Utkarsh AyachitNote Added: 0030743
2013-05-15 13:29Alan ScottNote Added: 0030769
2013-05-15 13:29Alan ScottStatuscustomer review => closed
2013-05-18 20:00Utkarsh AyachitFixed in Versiongit-master => 4.0
Notes
(0016733)
Julien Finet
2009-06-17 08:14
(edited on: 2009-06-17 10:51)
The inappropriate lines to the X axe are not an interpolation problem.
It is just that invalid points are not handled by charts. Valid and invalid points are systematically drawn.
(0025139)
Marcus D. Hanwell
2011-01-28 14:02
It seems to me that we should make these NaN, and then I could improve the charts to handle NaN correctly. Or, is there some reason that you would want to distinguish between invalid points and true NaN?
(0025176)
Ken Moreland
2011-01-31 10:03
I think using NaN as the identifier for invalid points is perfectly fine. All the NaNs I've seen in real data so far have been used to signify "invalid" or "no data". We were also proposing the use of NaN instead of the vtkValidPointMask to plot multiple series where each series may have different sets of valid values (for example if plotting a line over multiblock data with different fields in different blocks).
(0025177)
Marcus D. Hanwell
2011-01-31 10:11
That is good to hear, and the NaN solution seems more flexible than the valid point mask which would affect all rows. I also think the solution using NaNs would be more generally useful to the VTK community outside of ParaView. I will try to complete this work (I already have a list of invalid points in any particular plot in order to find a valid range - extending it to build up multiple lines is the next logical step).
(0025179)
Ken Moreland
2011-01-31 10:29
Be careful because NaN is not fully supported by VTK. I've pushed to have NaN be used in some parts of ParaView and have updated some small parts of VTK to handle NaNs better. However, almost all filters in VTK have no concept of NaN and some will freak out when they get one.
Anyway, I guess my point is that you should have a conversation with Berk before implementing this. I support the use of NaNs but he might have a second opinion.
(0025180)
Marcus D. Hanwell
2011-01-31 10:34
I think in the case of charts it is a little simpler - they are end consumers of the numbers (nothing beyond them in a pipeline). There has been code to handle NaNs, infinity etc for over a year now I think. I was just going to extend this into the rendering routines a little further, there are already a couple of bugs due to inconsistent handling of NaNs by OpenGL implementations - stopping the NaNs getting that far should fix those issues. I will get a second opinion to see if there is anything I missed though.
(0030691)
Utkarsh Ayachit
2013-05-03 14:03
I believe this is already fixed.
(0030743)
Utkarsh Ayachit
2013-05-10 08:23
SUMMARY
Topics merged into master:
        13853_catalyst_immediate_mode_rendering2
        13981_fix_install_rules
        13991_fix_window_sizes
        14040_add_save_animation_time_range_v2
        14046_fix_selection_issues
        14058_fix_camera_animation_in_parallel_scale
        14059-vtkPVGeometryFilter-unnecessary-array
        fix-custom-view-button-leak
        fix-multi-block-issues
        fix_pointsprite_plugin
        gmv-test-cleanup
        pvw-add-exit-button
(0030769)
Alan Scott
2013-05-15 13:29
Tested master, Linux, remote server.
I also tried running the output of the plot over line filter into a spreadsheet. It worked with the NAN's. I sorted the spreadsheet, and the NAN's didn't sort correctly. But, that is another bug.
