(0016666)
Andrew Hill
2009-06-09 07:09
Strongly agree with bug poster.
The default was changed from 1 to 5 because of bug 4197: http://www.paraview.org/Bug/view.php?id=4197 [^]
This bug stated that it was hard to see data sets consisting of a single point.
I would argue that it's now hard to see the detail in data consisting of even a few thousand points.
Where I work, typical data sets are at least 1 million points. Every single data set any of us loads has to be changed back to 'point size = 1' because the detail in the data can't be seen with point size = 5.
I don't imagine there's a 'one size fits all' solution to the default point size, but having the style defaults available in the configuration file (and/or better still, modifiable in the Options/Preferences window) seems like the best way around this.
Perhaps the default should still 'default' to 5 on creation of the ini file so that the data is at least visible if the user is unfamiliar with ParaView settings and/or the config file. |
(0016667)
David Doria
2009-06-09 07:23
Can a simple check of the number of vertices in the file be done to estimate a good point size?
< 10 vertices, point size 5
10 - 50 vertices, point size 4
> 10000 vertices, point size 1
I bet that's annoying (because of all the different file types?), but it seems like a good solution.
The user should also then be able to change that default behavior if desired. |
(0037641)
Kitware Robot
2016-08-12 09:57
Resolving issue as `moved`.
This issue tracker is no longer used. Further discussion of this issue may take place in the current ParaView Issues page linked in the banner at the top of this page. |
