MantisBT - ParaView | |||||
View Issue Details | |||||
0008868 | ParaView | Bug | public | 2009-04-09 03:35 | 2016-08-12 09:57 |
Reporter | Jean M. Favre | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0008868: structured grids of different extents cannot be used to resample one with the other | ||||
Description | I cannot resample one ImageData with another one of a different extent. The executive complains vtkCompositeDataPipeline (0x1491140): The update extent specified in the information for output port 0 on algorithm vtkRTAnalyticSource(0x1471ce0) is -10 10 -10 10 -10 10, which is outside the whole extent 0 30 0 30 0 30. IMHO, there should not be a check for matching extents. Probing (as in probing with an UnstructuredGrid which does work) should work irrespective of extents | ||||
Steps To Reproduce | |||||
Additional Information | a state file is provided to demonstrate the bug. | ||||
Relationships | |||||
Attached Files | resample.pvsm (139,548) 2009-04-09 03:35 https://www.vtk.org/Bug/file/7159/resample.pvsm | ||||
Issue History | |||||
2009-04-09 03:35 | Jean M. Favre | New Issue | |||
2009-04-09 03:35 | Jean M. Favre | File Added: resample.pvsm | |||
2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 | ||
2009-08-25 12:11 | Ken Moreland | Category | => Bug | ||
2009-08-25 12:11 | Ken Moreland | Target Version | 3.6 => 3.8 | ||
2016-08-12 09:57 | Kitware Robot | Note Added: 0037639 | |||
2016-08-12 09:57 | Kitware Robot | Status | expired => closed | ||
2016-08-12 09:57 | Kitware Robot | Resolution | open => moved | ||
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
Notes | |||||
