MantisBT - ParaView
View Issue Details
0008489ParaView(No Category)public2009-02-09 10:432009-05-13 13:46
Ken Moreland
Utkarsh Ayachit
lowminorhave not tried
closedfixed
3.6
0008489: Setting default color for solid colors
Users are requesting the ability to be able to change the default color for an object with a solid color and the color of the edges when Surface with Edges is on.
No tags attached.
Issue History
2009-02-09 10:43Ken MorelandNew Issue
2009-02-09 10:44Ken MorelandNote Added: 0014846
2009-02-17 16:48Utkarsh AyachitStatusbacklog => tabled
2009-02-17 16:48Utkarsh AyachitAssigned To => Utkarsh Ayachit
2009-02-17 16:48Utkarsh AyachitPrioritynormal => low
2009-02-25 15:11Utkarsh AyachitNote Added: 0015391
2009-02-25 15:11Utkarsh AyachitStatustabled => @80@
2009-02-25 15:11Utkarsh AyachitResolutionopen => fixed
2009-02-25 20:23Alan ScottNote Added: 0015403
2009-02-25 20:23Alan ScottStatus@80@ => closed
2009-05-13 13:46Utkarsh AyachitTarget Version => 3.6
2011-06-16 13:10Zack GalbreathCategory => (No Category)
Notes
(0014846)
Ken Moreland
2009-02-09 10:44
Making the solid colors "sticky" (default to the last one set) would be OK, but I think a better solution would be to have entries in the ParaView setting instead. That would prevent the current behavior from changing and prevent current regression tests from breaking.
In either case, the default color selection should be persistent between executions of ParaView. That is, the color selection should be saved in the ParaView settings file.
(0015391)
Utkarsh Ayachit
2009-02-25 15:11
Edge color are foreground color (default solid color) can now be changed through "Application Settings" dialog.
(0015403)
Alan Scott
2009-02-25 20:23
Great!
