MantisBT - ParaView | |||||
View Issue Details | |||||
0008445 | ParaView | (No Category) | public | 2009-01-29 20:46 | 2011-01-13 17:00 |
Reporter | Alan Scott | ||||
Priority | high | Severity | major | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | |||||
Target Version | 3.6 | Fixed in Version | |||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0008445: (Venus - High) Bad data when using logs with large numbers | ||||
Description | *ParaView, local server, XP (probably doesn't matter), 3.4.0. I will replicate with the trunk tonight. *Run disk_out_ref.exo. Turn all variables on. Apply. *Clip, apply. *Calculator. **Result Array Name = BadData **Formula = (Temp-293.14)*1e11 **Apply. You should now be coloring with BadData. *Edit Color Map. **Check Use logarithmic Scale. Close. *Surface With Edges. *+X *Select Points On, and then rubber band select the lower half of the lower right edge. In other words, select the bottom 2 rows, and about 4 columns of cells. *View/ Selection Inspector. **Point Label/ Label Mode BadData *Now, zoom in on the lower right section, and rotate so you can see the labels. Bug - Notice that we have created color bands. Furthermore, if you look at the bottom of the row, there are numerous blue points that should be whiteish - they are in the range of 1.2e11 to 1.6e11. This should be white. See attached screenshot. The banding is not an artifact - it shows up on my screen. I am marking this one important, since data is being misrepresented. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | badLogDataScreenshot.jpg (357,153) 2009-01-29 20:46 https://www.vtk.org/Bug/file/7023/badLogDataScreenshot.jpg | ||||
Issue History | |||||
2009-01-29 20:46 | Alan Scott | New Issue | |||
2009-01-29 20:46 | Alan Scott | File Added: badLogDataScreenshot.jpg | |||
2009-01-29 21:13 | Alan Scott | Note Added: 0014730 | |||
2009-02-02 21:08 | Alan Scott | Note Added: 0014761 | |||
2009-02-17 16:44 | Utkarsh Ayachit | Status | backlog => tabled | ||
2009-02-17 16:44 | Utkarsh Ayachit | Assigned To | => Burlen | ||
2009-02-26 17:36 | Alan Scott | Summary | Bad data when using logs with large numbers => (Venus - High) Bad data when using logs with large numbers | ||
2009-03-11 21:30 | Alan Scott | Note Added: 0015664 | |||
2009-03-11 21:57 | Alan Scott | Note Added: 0015665 | |||
2009-03-16 13:47 | Utkarsh Ayachit | Assigned To | Burlen => Utkarsh Ayachit | ||
2009-03-16 14:09 | Utkarsh Ayachit | Note Added: 0015699 | |||
2009-03-16 14:09 | Utkarsh Ayachit | Status | tabled => @80@ | ||
2009-03-16 14:09 | Utkarsh Ayachit | Resolution | open => fixed | ||
2009-03-17 19:20 | Alan Scott | Note Added: 0015720 | |||
2009-03-17 19:20 | Alan Scott | Status | @80@ => closed | ||
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 | ||
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |||
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |||
Notes | |||||
