MantisBT - ParaView | |||||
View Issue Details | |||||
0007730 | ParaView | (No Category) | public | 2008-09-24 16:01 | 2009-05-13 13:59 |
Reporter | Alan Scott | ||||
Priority | high | Severity | major | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | |||||
Target Version | 3.4 | Fixed in Version | 3.4 | ||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0007730: Edit Color Map icon is bad | ||||
Description | This is replicated on ParaView trunk, assuming it is in 3.4. It must be fixed for the 3.4 release, if possible. Local server. XP. * Open disk_out_ref.exo. All variables on. Apply. * Rotate the can so you can see inside. * Edit_Color_Map icon on the main toolbar. * Change color to dark red (top row, second from left). OK. >>> Error - nothing changes. * Next, change Solid Color to Temp. >>> Error - All of the blue has gone black. Should a change to the solid color really effect the lights? I checked lights, they look OK. I checked materials (through the Edit Color Map on the Display tab), they seem OK. * Note - I am using one headlight. Changing headlight color back to white didn't fix it. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2008-09-24 16:01 | Alan Scott | New Issue | |||
2008-09-24 16:01 | Alan Scott | Status | backlog => tabled | ||
2008-09-24 16:01 | Alan Scott | Assigned To | => Utkarsh Ayachit | ||
2008-09-25 13:46 | Utkarsh Ayachit | Status | tabled => @80@ | ||
2008-09-25 13:46 | Utkarsh Ayachit | Resolution | open => fixed | ||
2008-09-25 13:46 | Utkarsh Ayachit | Note Added: 0013582 | |||
2008-09-26 20:26 | Alan Scott | Status | @80@ => closed | ||
2008-09-26 20:26 | Alan Scott | Note Added: 0013611 | |||
2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 | ||
2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 | ||
Notes | |||||
