(0012949)
Utkarsh Ayachit
2008-08-06 13:04
I could not reproduce this. Has this been fixed since it was reported? |
(0012967)
Alan Scott
2008-08-07 17:01
I can easily reproduce this. It may be easier than this, but this works.
* Client/server. 6 servers.
* Turn on selection inspector.
* Sources/ Sphere.
* Click "Set view direction to X+" (next to reset)
* Select cells, rubber band select a rectangle area in the middle of the sphere.
* Invert selection.
* Rotate the sphere. Only half will be selected(with a hole where we turned off the original selection) |
(0012979)
Utkarsh Ayachit
2008-08-11 09:55
This fixes the following bug:
* run ParaView in parallel
* create a selection such no ids on atleast one of the processes were selected
* invert selection.
The process on which no ids were selected ended up creating no selection at all.
This was due to the fact that the vtkSelectionSource was not producing a
complete vtkSelection in its output if there are no ids. Which was incorrect in
case of inverse-selection. Hence now vtkSelectionSource::RequestData() ensures
that the vtkSelection in the output is constructed completely even is no ids are
present.
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkSelectionSource.cxx,v <-- VTK/Graphics/vtkSelectionSource.cxx
new revision: 1.25; previous revision: 1.24 |
(0013023)
Alan Scott
2008-08-14 16:36
This fixes it! Tested client/server. |
