MantisBT - ParaView |
| View Issue Details |
| 0007238 | ParaView | (No Category) | public | 2008-06-25 05:24 | 2009-05-13 13:45 |
| Reporter | Stephane P | |
| Assigned To | Utkarsh Ayachit | |
| Priority | normal | Severity | minor | Reproducibility | always |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | | |
| Target Version | 3.6 | Fixed in Version | | |
| Project | ParaViS |
| Topic Name | |
| Type | |
| Summary | 0007238: bug with IceT with multiple views : the interval between views is not cleared |
| Description | When using IceT with multiple views, there is a small gap between the views that is not cleared.
To reproduce it :
launch the server with pvserver -tdx=1, connect to it,
load the interval.pvsm state, and move the separation between the two views. |
| Steps To Reproduce | |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | |
| Attached Files | interval.pvsm (130,409) 2008-06-25 05:24 https://www.vtk.org/Bug/file/6562/interval.pvsm
BugFix-7238-Oct-9-2008.diff (24,361) 2008-10-10 15:55 https://www.vtk.org/Bug/file/6766/BugFix-7238-Oct-9-2008.diff |
| Issue History |
| 2008-06-25 05:24 | Stephane P | New Issue | |
| 2008-06-25 05:24 | Stephane P | File Added: interval.pvsm | |
| 2008-06-25 09:56 | Ken Moreland | Note Added: 0012521 | |
| 2008-06-25 09:56 | Ken Moreland | Category | 3.4 => 3.6 |
| 2008-10-09 09:01 | Utkarsh Ayachit | Status | backlog => tabled |
| 2008-10-09 09:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2008-10-09 09:01 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => |
| 2008-10-10 15:55 | Pat Marion | File Added: BugFix-7238-Oct-9-2008.diff | |
| 2008-10-10 15:56 | Pat Marion | Note Added: 0013848 | |
| 2009-02-17 18:56 | Ken Moreland | Category | 3.6 => Pending |
| 2009-02-20 11:07 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
| 2009-02-20 11:07 | Ken Moreland | Category | Pending => 3.6 |
| 2009-02-20 12:10 | Pat Marion | Note Added: 0015256 | |
| 2009-04-03 09:58 | Utkarsh Ayachit | Note Added: 0015897 | |
| 2009-04-03 09:58 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2009-04-03 09:58 | Utkarsh Ayachit | Resolution | open => fixed |
| 2009-04-15 16:56 | Alan Scott | Note Added: 0016035 | |
| 2009-04-15 16:56 | Alan Scott | Status | @80@ => closed |
| 2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| 2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
(0012521)
Ken Moreland
2008-06-25 09:56
The gap between the views is an all around nuisance, especially when you have lots of views on a display much larger than the GUI. The gaps between views are proportional to those in the GUI. Because everything is scaled up the same, the gaps are often too large, especially in the vertical direction.
Rather than clear out the spaces, it would be nice to just make the views larger to abut each other. This would probably require the GUI to report view dimensions that extend into the GUI around its borders. Of course, that should only be done in tile display mode, not desktop delivery mode. |
(0013848)
Pat Marion
2008-10-10 15:56
I've uploaded a bugfix patch, might not be ready for cvs until more testing is done. |
(0015256)
Pat Marion
2009-02-20 12:10
In the bugfix patch, the main algorithm is pqMultiView::computeCompactSizes. This algorithm does what Ken describes above.
Everything else is just code to move the new size values to the server. |
(0015897)
Utkarsh Ayachit
2009-04-03 09:58
Committing Pat's patch for collapsing gaps between views on the server side on a tile display.
/cvsroot/ParaView3/ParaView3/Qt/Components/pqMultiView.cxx,v <-- Qt/Components/pqMultiView.cxx
new revision: 1.20; previous revision: 1.19
/cvsroot/ParaView3/ParaView3/Qt/Components/pqMultiView.h,v <-- Qt/Components/pqMultiView.h
new revision: 1.14; previous revision: 1.13
/cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.cxx,v <-- Qt/Components/pqViewManager.cxx
new revision: 1.68; previous revision: 1.67
/cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.h,v <-- Qt/Components/pqViewManager.h
new revision: 1.26; previous revision: 1.25
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVDesktopDeliveryClient.cxx,v <-- Servers/Filters/vtkPVDesktopDeliveryClient.cxx
new revision: 1.10; previous revision: 1.9
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVDesktopDeliveryClient.h,v <-- Servers/Filters/vtkPVDesktopDeliveryClient.h
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVDesktopDeliveryServer.cxx,v <-- Servers/Filters/vtkPVDesktopDeliveryServer.cxx
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVDesktopDeliveryServer.h,v <-- Servers/Filters/vtkPVDesktopDeliveryServer.h
new revision: 1.11; previous revision: 1.10
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml
new revision: 1.340; previous revision: 1.339
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.cxx,v <-- Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.cxx
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.h,v <-- Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.h
new revision: 1.5; previous revision: 1.4 |
(0016035)
Alan Scott
2009-04-15 16:56
I think I understand the fix. If not, please reopen this bug.
Tested client/ remote server with the tdx switch listed below. |
