MantisBT - ParaView | |||||
View Issue Details | |||||
0007173 | ParaView | (No Category) | public | 2008-06-08 14:24 | 2009-05-13 13:59 |
Reporter | Berk Geveci | ||||
Assigned To | Burlen | ||||
Priority | high | Severity | minor | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | |||||
Target Version | 3.4 | Fixed in Version | 3.4 | ||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0007173: Leak with vtkCTHFragmentConnect | ||||
Description | To reproduce, load a CTH dataset, apply vtkCTHFragmentConnect, exit paraview. If VTK_DEBUG_LEAKS is on, the following leaks are reported: vtkDebugLeaks has detected LEAKS! Class "vtkSpyPlotUniReader" has 4 instances still around. Class "vtkCellData" has 114 instances still around. Class "vtkCollection" has 1 instance still around. Class "vtkInformationIntegerVectorValue" has 114 instances still around. Class "vtkInformationVector" has 1158 instances still around. Class "vtkDataArraySelection" has 2 instances still around. Class "vtkSpyPlotReader" has 1 instance still around. Class "vtkPointData" has 114 instances still around. Class "vtkHierarchicalBoxDataIterator" has 2 instances still around. Class "vtkCompositeDataPipeline" has 6 instances still around. Class "vtkTrivialProducer" has 119 instances still around. Class "vtkDummyController" has 1 instance still around. Class "vtkPoints" has 1026 instances still around. Class "vtkIntArray" has 3 instances still around. Class "vtkInformation" has 2458 instances still around. Class "vtkLine" has 456 instances still around. Class "vtkInformationIntegerPointerValue" has 114 instances still around. Class "vtkPixel" has 228 instances still around. Class "vtkPVExtentTranslator" has 1 instance still around. Class "vtkUniformGrid" has 114 instances still around. Class "vtkIdList" has 1026 instances still around. Class "vtkStructuredVisibilityConstraint" has 228 instances still around. Class "vtkEmptyCell" has 114 instances still around. Class "vtkDoubleArray" has 1028 instances still around. Class "vtkAlgorithmOutput" has 120 instances still around. Class "vtkInformationIntegerValue" has 187 instances still around. Class "vtkHierarchicalBoxDataSet" has 1 instance still around. Class "vtkVertex" has 114 instances still around. Class "vtkMultiPieceDataSet" has 5 instances still around. Class "vtkInformationStringValue" has 6 instances still around. Class "vtkFloatArray" has 1254 instances still around. Class "vtkInformationExecutivePortVectorValue" has 1 instance still around. Class "vtkDummyCommunicator" has 2 instances still around. Class "vtkVoxel" has 114 instances still around. Class "vtkFieldData" has 120 instances still around. Class "vtkInformationDoubleVectorValue" has 1146 instances still around. Class "vtkUnsignedCharArray" has 342 instances still around. Class "vtkStreamingDemandDrivenPipeline" has 114 instances still around. Class "vtkCommand or subclass" has 5 instances still around. Class "vtkMultiProcessControllerRMI" has 1 instance still around. Class "vtkInformationExecutivePortValue" has 120 instances still around. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2008-06-08 14:24 | Berk Geveci | New Issue | |||
2008-06-08 14:24 | Berk Geveci | Status | backlog => tabled | ||
2008-06-08 14:24 | Berk Geveci | Assigned To | => Burlen | ||
2008-06-11 14:47 | Burlen | Status | tabled => @80@ | ||
2008-06-11 14:47 | Burlen | Resolution | open => fixed | ||
2008-06-12 15:26 | Alan Scott | Status | @80@ => closed | ||
2008-06-12 15:26 | Alan Scott | Note Added: 0012334 | |||
2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 | ||
2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 | ||
Notes | |||||
