MantisBT - VTK | |||||
View Issue Details | |||||
0006844 | VTK | (No Category) | public | 2008-04-17 15:58 | 2016-08-12 09:54 |
Reporter | Ken Moreland | ||||
Product Version | |||||
Project | |||||
Type | |||||
Summary | 0006844: vtkCompositeDataPipeline::ShouldIterateOverInput ignores DATA_TYPE_NAME | ||||
Description | The method vtkCompositeDataPipeline::ShouldIterateOverInput decides whether the algorithm is "simple" and should be iteratively called on a composite data type. The current implementation of this method only looks at the vtkAlgorithm::INPUT_REQUIRED_DATA_TYPE key and not the vtkDataObject::DATA_TYPE_NAME. This means that if any object that uses the DATA_TYPE_NAME key to specify its input (and there are many algorithms that still do) will be correctly connected to a source that produces composite data, but the request data pass will incorrectly pass the composite data to the algorithm rather than iterate the algorithm on all the blocks. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2008-04-17 15:58 | Ken Moreland | New Issue | |||
2011-06-16 13:11 | Zack Galbreath | Category | => (No Category) | ||
2016-08-12 09:54 | Kitware Robot | Note Added: 0036969 | |||
2016-08-12 09:54 | Kitware Robot | Status | expired => closed | ||
2016-08-12 09:54 | Kitware Robot | Resolution | open => moved | ||
2016-08-12 09:54 | Kitware Robot | Assigned To | => Kitware Robot |
Notes | |||||
