(0011760)
Berk Geveci
2008-05-08 13:51
Re-enable but add a warning if number of ids in the selection is larger than 10000. |
(0011819)
Utkarsh Ayachit
2008-05-12 11:37
It's now possible to convert frustum selection to
id/global-id selection. If number of IDs is > 10,000, then a warning is flashed.
commitid: Jh2cL1CYGUdIOG2t;
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.cxx,v <-- Servers/ServerManager/vtkSMSelectionHelper.cxx
new revision: 1.16; previous revision: 1.15
/cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.cxx,v <-- Qt/Components/pqSelectionInspectorPanel.cxx
new revision: 1.27; previous revision: 1.26 |
(0011877)
Alan Scott
2008-05-13 19:05
When I select Global ID's, I get lots of grumbling verbage back. Is this expected behavior? Local ParaView, XP. |
(0011897)
Ken Moreland
2008-05-14 10:37
Can you be more specific about the grumbling? I just loaded disk_out_ref, selected the entire thing with a frustum select (either points or cells) and then converted to global ids. The process was silent. |
(0011900)
Utkarsh Ayachit
2008-05-14 10:45
Alan,
There was a bug in PVGeometryFilter that I fixed (probably yesterday) which was causing some errors on the (process > 0). So you may want to update before trying it out again. |
(0012062)
Alan Scott
2008-05-21 23:10
OK, that fixed the grumbling - too many error messages issue.
Next, I did the following (seems to need to be done exactly as follows):
* Wavelet source.
* Representation: Surface.
* Select cells through.
* Rotate the wavelet with the left mouse button.
* Selection inspector, change selection type from frustum to IDs.
* Selection inspector, change selection type from IDs to Global IDs. The select goes away - should it?
* Selection inspector, change selection type from Global IDs to IDs.
* Rotate the cube, and you will find that multiple random cells are now selected. Surely this shouldn't be happening...
Client/Server, 6 pvservers, XP client. |
(0012162)
Utkarsh Ayachit
2008-05-30 10:32
Conversion to global ids should not be available to wavelet since wavelet doesn't produce gloabl ids. Added a new bug 0007126 for that. |
(0012196)
Alan Scott
2008-06-02 19:12
Fixed. Tested as per my notes below. |
