MantisBT - ParaView
View Issue Details
0006768ParaView(No Category)public2008-04-07 17:532016-08-12 09:57
Ken Moreland
Utkarsh Ayachit
lowminorhave not tried
closedmoved
Someday
0006768: Select any array as texture coordinates
Right now, you can only use an array for texture coordinates if it is assigned as the active texture coordinates in the data structure. Furthermore, there is no direct way to set the active texture coordinates.
A better approach (I think) is to be able to select any array to use as the texture coordinates.
No tags attached.
related to 0004788closed Utkarsh Ayachit Texture mapping
Issue History
2008-04-07 17:53Ken MorelandNew Issue
2008-04-07 17:53Ken MorelandStatusbacklog => tabled
2008-04-07 17:53Ken MorelandAssigned To => Utkarsh Ayachit
2008-04-07 17:53Ken MorelandPrioritynormal => low
2008-04-07 17:55Ken MorelandNote Added: 0011131
2008-04-10 16:11Utkarsh AyachitRelationship addedrelated to 0004788
2009-03-20 17:06Ken MorelandCategory3.6 => Someday
2009-05-13 13:49Utkarsh AyachitTarget Version => Someday
2011-06-16 13:10Zack GalbreathCategory => (No Category)
2016-08-12 09:57Kitware RobotNote Added: 0037562
2016-08-12 09:57Kitware RobotStatusexpired => closed
2016-08-12 09:57Kitware RobotResolutionopen => moved
Notes
(0011131)
Ken Moreland
2008-04-07 17:55
This is not a user request (yet); it's just one of those pie-in-the-sky I-think-we-should-have-that requests. I don't know for sure if we will need this, but I'm quite sure that the current method of getting texture coordinates will not be sufficient for anyone serious about texture mapping. I figure this method should be fairly easy to implement and powerful enough to handle future use cases.
(0037562)
Kitware Robot
2016-08-12 09:57
Resolving issue as `moved`.
