MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0006734 | ParaView | Bug | public | 2008-04-07 13:47 | 2010-11-16 18:39 |
| Reporter | amaclean | ||||
| Assigned To | David Partyka | ||||
| Priority | normal | Severity | major | Reproducibility | always |
| Status | closed | Resolution | no change required | ||
| Product Version | |||||
| Target Version | Someday | Fixed in Version | 3.8 | ||
| Project | |||||
| Topic Name | |||||
| Type | |||||
| Summary | 0006734: Installation of Paraview | ||||
| Description | Install fails when it reaches this point because "C:\Q" is not being treated as C:/Q. See the output below: 1>-- Installing: C:/Program Files/ParaView/bin/QTASSISTANTCLIENT4.dll 1>CMake Error: Invalid escape sequence \Q 1>Syntax error in cmake code at 1>C:/Users/amaclean/Code/Kitware/build/ParaView/Applications/Client/cmake_install.cmake:82: 1>syntax error, unexpected cal_ERROR, expecting $end (4), when parsing string "C:\Qt\qt-win-opensource-src-4.3.4\bin/assistant.exe" 1>-- Installing: C:/Program Files/ParaView/bin/assistant.exe 1>-- Installing: C:/Program Files/ParaView/bin/pvTestDriver.exe 1>Project : error PRJ0019: A tool returned an error code from "Performing Post-Build Event..." | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2008-04-07 13:47 | amaclean | New Issue | |||
| 2008-04-15 12:53 | Berk Geveci | Status | backlog => @30@ | ||
| 2008-04-15 12:53 | Berk Geveci | Category | Development => 3.6 | ||
| 2009-02-17 14:11 | Ken Moreland | Category | 3.6 => Someday | ||
| 2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday | ||
| 2010-07-14 14:18 | Utkarsh Ayachit | Note Added: 0021393 | |||
| 2010-07-14 14:18 | Utkarsh Ayachit | Resolution | open => won't fix | ||
| 2010-07-14 14:18 | Utkarsh Ayachit | Category | => Bug | ||
| 2010-11-11 09:23 | David Partyka | Status | @30@ => tabled | ||
| 2010-11-11 09:23 | David Partyka | Assigned To | => David Partyka | ||
| 2010-11-11 09:25 | David Partyka | Note Added: 0023166 | |||
| 2010-11-11 09:25 | David Partyka | Status | tabled => @80@ | ||
| 2010-11-11 09:25 | David Partyka | Fixed in Version | => 3.8 | ||
| 2010-11-11 09:25 | David Partyka | Resolution | won't fix => no change required | ||
| 2010-11-16 18:39 | Alan Scott | Note Added: 0023321 | |||
| 2010-11-16 18:39 | Alan Scott | Status | @80@ => closed | ||
| Notes | |||||
