(0010025)
Utkarsh Ayachit
2007-12-27 11:04
Fixes for BUG 0005895 and BUG 0005894. Added support to save screenshot of all
views. Plot views also correctly save high resimages (except pdf) via screenshot
as well as when saving animation.
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMAnimationSceneImageWriter.h,v <-- vtkSMAnimationSceneImageWriter.h
/cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationManager.cxx,v <-- pqAnimationManager.cxx
new revision: 1.28; previous revision: 1.27
/cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationManager.h,v <-- pqAnimationManager.h
new revision: 1.14; previous revision: 1.13
/cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx
new revision: 1.243; previous revision: 1.242
/cvsroot/ParaView3/ParaView3/Qt/Components/pqSaveSnapshotDialog.cxx,v <-- pqSaveSnapshotDialog.cxx
new revision: 1.2; previous revision: 1.1
/cvsroot/ParaView3/ParaView3/Qt/Components/pqSaveSnapshotDialog.h,v <-- pqSaveSnapshotDialog.h
/cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.cxx,v <-- pqViewManager.cxx
new revision: 1.50; previous revision: 1.49
/cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.h,v <-- pqViewManager.h
new revision: 1.18; previous revision: 1.17
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSaveSnapshotDialog.ui,v <-- pqSaveSnapshotDialog.ui
/cvsroot/ParaView3/ParaView3/Qt/Core/pqPlotView.cxx,v <-- pqPlotView.cxx
new revision: 1.19; previous revision: 1.18 |
(0010066)
Alan Scott
2008-01-03 18:44
When a user saves screenshot, and turns off the checkbox "Save only selected view", the size does not change. This makes the whole window small. For instance,
Open disk_out_ref.exo.
Split horizontal.
Split both viewports vertically.
Put something in each, creating a set of 2 column by 2 row windows.
Make sure that one of the four windows is highlighted.
File/Save Screenshot.
Resolution will be 612x449 (on my monitor)
Unselect "Save only selected view".
Resolution stays as 612x449, where it should be something like 1200x900.
alan |
(0010195)
Utkarsh Ayachit
2008-01-18 13:53
When user toggles the "Save only selected view" check box, the sizes are updated.
new revision: 1.247; previous revision: 1.246
new revision: 1.4; previous revision: 1.3
new revision: 1.3; previous revision: 1.2 |
(0010251)
Alan Scott
2008-01-23 15:30
I just checked client/server. single window works fine, selected view off failed.
* Open can, accept.
* Horizontal split, turn on eyeball, turn can another direction.
* Save screenshot, save only selected view off. (Size does change correctly)
* Error in vtkImageData.cxx, line 1460. vtkImageData: GetScalarPointer: Pixel (1233,927, 0) not in memory. Current extent= (0,1232, 0, 927, 0, 0) |
(0010661)
Utkarsh Ayachit
2008-02-27 21:50
I wasn't able to reproduce this. Can you verify if this is fixed? |
(0011134)
Ken Moreland
2008-04-07 18:19
Working for me, too. Looks like it's fixed now. |
(0011144)
Alan Scott
2008-04-07 19:30
